A great way to cover the front bumper drilled license plate holes... using BMW parts!
Discussion in 'Gen 3 Prius Accessories and Modifications' started by E46Prius, Aug 11, 2015.
  1. E46Prius
    E46Prius Active Member
    314
    219
    Costa Mesa
    So since I have a ton of brand new BMW parts laying around from my other car, I used these BMW expanding push clips to cover the holes in my front bumper. I had to use a slightly larger drill bit to further enlarge the hole (tiny amount) and they push in perfectly. I painted and clearcoated them to have a reasonable match with the car. Voila. They work great. They're like a buck each. BMW part# 51498237075. Of course you'll only use the top part of the clip. Discard the lower expanding part. You may find other parts (maybe even Toyota parts) of similar type would work too. But I had these lying around. Nothing beats free. Unless you guys have other parts that you've used?
    BMW E46 330i M54 3.0L - 51498237075 - Expanding Rivet - Plastic Fastener - ES#126928
    Starbrand, qdllc, HelloHybrid and 2 others like this.
  2. HelloHybrid
    HelloHybrid Senior Member
    482
    1,483
    I've used bumperplugs.com before. From your pic, your BMW rivets look a little more flush.
  3. qdllc
    qdllc Senior Member
    1,374
    399
    Nice find. I may never need it, but some people whine so much about those front plate holes as if there's nothing to be done about them.
  4. Mendel Leisk
    40,938
    Looks good.
    Still, you could just put the license plate on, quit being an outlaw. :ROFLMAO:
    Accordlayingkit likes this.
  5. E46Prius
    314
    219
    Costa Mesa
    Agreed... but I've gotta do something to the Prius from looking like every other Prius =p I come from a modified manual transmission BMW 3-Series so I have to do some tasteful things to set my car apart and make it enjoyable as possible. Plus I'm fairly sure the Prius's .25 drag coefficient was achieved without the license plate. That can't be good for aero
    I've driven my cars the past 10 years without any front plate. So far so good. In the old days (when I was a kid) i used to get front plate tickets but thats only cause they were tacked on for other driving offenses. I'm older now so I'm (mostly) well behaved =)
  6. xliderider
    xliderider Senior Member
    8,125
    3,265
    Honolulu, HI
  7. E46Prius
    314
    219
    Costa Mesa
    Can't say I'm a fan of that. Reminds me of boy racers. Also not a fan of airflow being blocked to the radiator/condenser. (assuming that's what the air flow is for on this particular car)
  8. xliderider
    8,125
    3,265
    Honolulu, HI
    Then there is the tow hook license plate mount.
    HelloHybrid likes this.
  9. E46Prius
    314
    219
    Costa Mesa
    Argghhhh that's even worse! Maybe when I was in high school driving a dragging on the ground civic with a $10 exhaust hahaha :) I like the stock factory tasteful premium location if I werre to use a plate. But no plate is optimal! :)
  10. el Crucero
    el Crucero Senior Member
    1,628
    699
    Inland Empire
    Call me a boy racer! ;) :p
  11. el Crucero
    1,628
    699
    Inland Empire
    Then call me a boy racer! ;) :p
  12. xliderider
    8,125
    3,265
    Honolulu, HI
    Ok, OP, no crying if you get a ticket. ;) :D
