Noob questions
Discussion in 'Gen 3 Prius Main Forum' started by zzrguy, Aug 16, 2015.
  1. zzrguy
    zzrguy Junior Member
    88
    ny
    Alright when driving in B is the engine running to help slow the car or is it the traction motor that is slowing the car?
  2. 348
    348 Junior Member
    71
    36
    Central Oregon
    Anyone??
    I know it's 'probably in one of the several manuals that came with my new P but I much to lazy to open them. Hell, I only finally opened the hood to put more wiper fluid in!
  3. bisco
    52,386
    don't drive in b.
  4. Oskar
    Oskar Member
    249
    96
    Massachusetts
    2020 Prius Prime
    Why?
  5. bisco
    52,386
    reduced mpg's.
  6. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    Above 24 MPH, B always gets worse gas mileage than D.when slowing. You want to use B at the top of long downhills that will fill the battery past Toyota's ideal. (This is JUST like when you would use L in an automatic, but the Prius is not in a Lower gear, it uses engine Breaking)
  7. Oskar
    Oskar Member
    249
    96
    Massachusetts
    2020 Prius Prime
    Oh, OK. I thought it was used when going down steep hills, etc. That's the only time I use it.
  8. bisco
    52,386
    exactly. no one really knows what's happening internally when it's used. toyota just says it's to reduce brake wear.
  9. el Crucero
    el Crucero Senior Member
    1,628
    699
    Inland Empire
    In my opinion, you are using it correctly.
  10. zzrguy
    88
    ny
    OK but is it using engine or motor to slow the car.
  11. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
  12. el Crucero
    1,628
    699
    Inland Empire
    According to my HSI, it is using the electric motor to slow the car up to a certain speed and then the ICE kicks in and the brakes the car.
  13. bisco
    52,386
    if anyone subscribes to sae, there might be a white paper.
  14. zzrguy
    88
    ny
    Ok thanks I didn't see it in the owner manual so figured I ask.
  15. CR94
    CR94 Senior Member
    2,749
    1,204
    Northwestern S.C.
    ??? We do know what's happening, at least the general idea, if not every detail. In "B" the system uses a motor (MG1) to apply torque to resist being spun by the wheels. That forces the engine to spin faster than it otherwise would, absorbing some of the excess energy that would otherwise have to go into the battery or friction brakes on a serious downhill. If you must step on the brake moderately at the same time, the effect is increased, so the engine spins even faster.
    Don't use "B" except on long, steep mountain descents that would fill the battery or require heavy use of the friction brakes. It's just an alternate way of throwing away energy when that's necessary, much as one might downshift a conventional automatic or manual transmission for the same reason.
    #15 CR94, Aug 17, 2015
    CaliforniaBear likes this.
  16. bisco
    52,386
    eventually, someone will correct you.:p
