Please recommend good quality/inexpensive tire pressure gauge
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Southpaw1969, Sep 13, 2015.
  1. Southpaw1969
    Southpaw1969 New Member
    22
    SoCal
    Just like the title says, can someone please recommend a decent tire air pressure gauge I can buy online- say on Amazon?
    I'd prefer one with a bleed valve to make getting the right pressure level easier.
    Thanks!
  2. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    Save yourself the shipping fees. Go to a auto parts house and buy one.
    I prefer the pencil type gages. Other's will say different things. Each person has their own individual likes and dislikes.
    Here is a example of a pencil type gage.
    Super price on Milton S-920 at ToolTopia.com
  3. Southpaw1969
    22
    SoCal
    Thanks, but I'm not a fan of those. They are built into the air hoses I tend to use anyway.
    I want one with a bleed valve so I can just overfill the tire a little bit, then use the bleed valve to back it down to exactly where I want it. Also, FYI, I have Amazon prime so I get free 2 day shipping on most items.
  4. dorunron
    3,318
    1,105
    Houston, TX
    Understood, best of luck to you. Like I said, everyone has their own preferences.
  5. dorunron
    3,318
    1,105
    Houston, TX
  6. dorunron
    3,318
    1,105
    Houston, TX
    I think the above is exactly what you are asking for.
  7. Southpaw1969
    22
    SoCal
    I was looking at that very one- was hoping someone here has used it and can vouch for quality/accuracy.
  8. sdtundra
    sdtundra Senior Member
    1,314
    193
    Sacramento, CA
    I've been using this one since January and its accurate with 3 different air hoses at the shop I work in. Accutire
    MS-4021B
  9. dorunron
    3,318
    1,105
    Houston, TX
    Here's another one, for more money.
  10. bisco
    51,895
    no one knows if their air gauge is accurate. i have 3 pencil gauges that are within 2 lbs of each other. that's good enough for me. i just use the back side to release pressure, it's quick and easy.
  11. fotomoto
    fotomoto Senior Member
    5,635
    3,812
    So. Texas
    Unless you're going racing where the difference between a pound or two can mean the difference between making through the turn versus hitting the wall, you want a precision (repeatability) gauge first, accuracy second.
    Here's a report that shows pencil gauges, albeit low tech, work really well. Comparison Tests on Tire Pressure Gauges
  12. xliderider
    xliderider Senior Member
    8,140
    3,276
    Honolulu, HI
    I prefer dial type gauges:
  13. M in KC
    M in KC Active Member
    358
    106
    KC, MO
    ^ What Xliderider says. Accu-Gauge with the short whip hose. If it doesn't come with the protective rubber outer guard order one separate.
  14. Mendel Leisk
    41,401
    I rely primarily on a pencil gauge I've had for decades. It's scale goes high enough to check the (60 psi) spare as well. I picked up a cheapish digital scale and it gives the same readings, so it looks like it's a keeper.
    I couldn't find the pencil gauge one time, bought another, seemed like decent quality, but I COULD NOT get the new gauge to seat properly on the valve rim: air would bleed out like crazy. Not sure why, gasket looks perfect. Anyway, I found the old one, so all is good.
    The rubber gasket on it is starting to look a little knackered though, may have to break down and shop for a new one some time. You pays your money and takes your chances. :)
    Checked mine, its:
    PCL tyre pressure gauge
    Made in England, by Pneumatic Components Ltd
    Displayed range: 10~120 psi
    #14 Mendel Leisk, Sep 14, 2015
  15. E Risch
    E Risch Junior Member
    49
    Nashville
