TRS Morimoto Elite H11 HID kit issue
Discussion in 'Gen 3 Prius Accessories and Modifications' started by 4rpr15, Sep 25, 2015.
  1. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    You've been lucky.
    There's always going to be people who claim to never have any problems in every type of car, etc. It doesn't help the individuals who do have problems.
    Then again, the OP, for whatever reason, seems to be resistant to installing an HID relay harness, which may have solved the problem. SMH
  2. 4rpr15
    4rpr15 Senior Member
    1,056
    375
    WI
    I agree, but the car is telling me something else when I switch the lights on at times.
  3. xliderider
    8,140
    3,277
    Honolulu, HI
    Also, I've read that HID bulbs are harder to restart when warm (not cold start). So if the no start problem occurred after the lights were in use, then shutdown briefly, then attempted to restart, that might have contributed to the problem.
  4. 4rpr15
    1,056
    375
    WI
    Not quite. I parked my Prius once and came back in an hour after shopping. One headlight would only turn on.
  5. xliderider
    8,140
    3,277
    Honolulu, HI
  6. 4rpr15
    1,056
    375
    WI
  7. trentofdestiny
    trentofdestiny Master Finagler
    1,104
    227
    Harrisburg, PA
    Yes I've noticed this as well. Many short errands in one trip where you're turning the car (and lights) on for 20 minutes, turning them off for 5 while you run in a store, then repeating a few times.
    iPhone ?
  8. 4rpr15
    1,056
    375
    WI
    One of your headlights wouldn't turn on?
  9. trentofdestiny
    1,104
    227
    Harrisburg, PA
    Wouldn't turn on with the car. Had to flip off on then it worked. Another quirk I have is, sometimes when I turn the lights off, the radio turns off. Haha it's intermittent and I'm sure it's EFI interference from the ballast but it's not hurting anything.
    iPhone ?
    4rpr15 likes this.
  10. 99estoril
    99estoril Junior Member
    PA
    let us know how you like the alpha kit compared to the TRS. Which temp bulb did you go with? I looked on their site, but had no luck finding where you can add the harness for $11?
  11. 4rpr15
    1,056
    375
    WI
    5000k. A rep from Alpha emailed that info to me.
  12. 4rpr15
    1,056
    375
    WI
    Received the Alpha Kit. This it looks and feels great. The only thing I'm stumped on is where the red and black wires plug into. [​IMG]
  13. xliderider
    8,140
    3,277
    Honolulu, HI
    Those plug into your oem lowbeam connector (the one that would've plugged into the oem bulb.
    It's a bad sign that they didn't provide the H11 connector for your application. :(
  14. 4rpr15
    1,056
    375
    WI
    After trying out the kit it's horrible. It's going back.
  15. xliderider
    8,140
    3,277
    Honolulu, HI
    You should've stayed with the Morimoto HID and added the HD dual relay HID harness.
  16. 4rpr15
    1,056
    375
    WI
    I prefer led.
  17. trentofdestiny
    1,104
    227
    Harrisburg, PA
    LED if done right should be about $600-1000 using OEM parts
    iPhone ?
  18. 4rpr15
    1,056
    375
    WI
    I don't get how xenondepot could sell that led kit if they are truly that bad and dangerous. They are a very well known led and hit online company. Many forums have praised them as well.
  19. 4rpr15
    1,056
    375
    WI
    Hid kits are crap in general because of glare(even though it's in a projector based headlight)
    Ballasts are usually not oem so they tend to blow out and not have the safety features necessary.
  20. trentofdestiny
    1,104
    227
    Harrisburg, PA
    Agreed. The odds are against them but they work...mostly. I would feel the same things apply to aftermarket LED kits though too...
    iPhone ?
