Navigation who can I complain to?
Discussion in 'Gen 2 Prius Main Forum' started by clifford, May 1, 2006.
  1. clifford
    clifford Member
    156
    <div class='quotetop'>QUOTE(SW03ES @ May 2 2006, 08:28 PM) [snapback]248833[/snapback]</div>
    While I am glad that you are totally satisfied with your older ES Nav I honestly don't think you would be as satisfied with the current modelES. Toyota/Lexus has made changes for some reason.
    When you up date your Lexus you may find a difference so please be aware.
    My daughter's boyfriend has a 2007 GS 300 with Nav. and has exactly the same problems as I have in my area (not dirt roads) city of 100,000. He is ready to head back to an Acura TL because of this system.
    Thanks for your reply.
    <div class='quotetop'>QUOTE(devprius @ May 2 2006, 06:24 PM) [snapback]248795[/snapback]</div>
    I hope that, eventually, I will be as satisfied as you are with the Prius, Nav. I also have a street pilot 2610 and also a Garmin IQUE M4. Yes the Prius has a larger screen. I don't really know what the advantage of the integrated system is for this Prius Nav. Maybe you can explain.
    <div class='quotetop'>QUOTE(Proteus @ May 1 2006, 10:49 PM) [snapback]248372[/snapback]</div>
    Finally someone who understands the step down. And this for approx. $2000!
    <div class='quotetop'>QUOTE(beeri @ May 2 2006, 01:59 AM) [snapback]248444[/snapback]</div>
    thanks for your suggestion.
    <div class='quotetop'>QUOTE(jgraner804 @ May 2 2006, 08:30 AM) [snapback]248503[/snapback]</div>
    That is great. I am so glad that yours does the job the unit is supposed to do.
    <div class='quotetop'>QUOTE(TonyPSchaefer @ May 1 2006, 10:25 PM) [snapback]248357[/snapback]</div>
    Is the a phone line?
    thanks
    <div class='quotetop'>QUOTE(daniel @ May 2 2006, 08:06 AM) [snapback]248485[/snapback]</div>
    I appreciate my street pilot also and also my iquem4 but I need to get this Prius Nav to work to my satisfaction also. It is, by far, the most expensive of all!
    <div class='quotetop'>QUOTE(mssmith95 @ May 2 2006, 09:01 AM) [snapback]248517[/snapback]</div>
    Thank you for your suggestion to turn off "allow freeway" that does make sense but I don't really understand why"allowing freeway" would take your 30 miles out of the way!
    <div class='quotetop'>QUOTE(clifford @ May 1 2006, 09:15 PM) [snapback]248315[/snapback]</div>
    So I am thinking what if I was able to come up with an older dvd install. Would I not have the restrictions that I have now with the current model?
