KNOWN Highest odometer original mileage recorded
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Dion Kraft, Nov 16, 2015.
  1. Dion Kraft
    Dion Kraft Member
    304
    92
    Washington, UT
    Who knows what the highest mileage is and what are the basic averages? 200,000 miles or more?
    I am looking at a 04 with 215K on the clock and was wondering how much more will it go. Basically I am going to use it to run around town so if it blows up its no big deal. I see used engines and trannys going for pretty cheap. This car is on sale for $5k. It is a Base model. If it blows labor is free. I am an prof auto mechanic
    Thanks in advance for your time.
    51,561
    welcome! i've heard 5-600,000 on some canadian taxi's. of course there are repairs involved.
    there's a thread here with posted mileage.
    if you don't mind fixing it, what exactly is your concern?
    are you wondering the highest miles without repairs?
  3. orenji
    orenji Senior Member
    5,887
    3,488
    Google it, there are cars with 600K and some with 400K on the original battery.
  4. Dion Kraft
    Dion Kraft Member
    304
    92
    Washington, UT
    Yeah..we'll fixing it is no problem for me it is that fixing things for a hobby is not what I had in mind it is more or less what to expect is the item. If I have to rip out the eng/trans out with the eng cradle its no biggy since I have a hoist at home. MaxJax. Tools..have them all or if not I buy them. But it is what I can do with my time is the big matter and I try to project what the problems can be BEFORE they happen.
    But luckily transportation is not a problem since I have now 12 cars at home and they all run. Most recent is the wifeys 09 Pruis fully loaded.
    Meanwhile I will opt for the high mileage Base model. 2004. I will checkout Google and see what gives as you suggested. Thanks!
  5. Dion Kraft
    Dion Kraft Member
    304
    92
    Washington, UT
    Thank u for your swift reply...I do recall that many are cabs and they would have to be reliable to meet those conditions. I should know..I used to be a CAB mechanic!! lol!
    orenji likes this.
  6. bisco
    51,561
    2004 was built like a tank. probably the fewest problems of all the gen II's. all the best!(y)
  7. Mendel Leisk
    41,009
    Weren't there some second gen's with odometer that stops at 300,000 miles? Or was that first gen??
  8. jdenenberg
    jdenenberg EE Professor
    3,938
    1,936
    Trumbull, CT
    2020 Prius
    LE AWD-e
    That was (is) the Gen2 2004 and 2005 versions the design flaw was fixed in the 2006+ versions. I have a 2004 - 20.5k miles till the odometer stops).
    JeffD
