Replacement Seat Help!!
Discussion in 'Prius c Accessories and Modifications' started by Ironball, Nov 13, 2015.
  1. Ironball
    Ironball New Member
    ONTARIO cANADA
    I have been reading countless posts on how bad the Prius C seats are but have yet to read the fix. Has anyone replaced/fixed the front seats of a 2013 Prius C to something that is not a medieval torture device? If anyone has a fix....Please tell me what you have done, what modifications works and what is most cost effective. We use this car as a commuter car and spend a lot of time in the seat. Thanks for your help guys!
  2. Munpot42
    Munpot42 Senior Member
    1,391
    544
    Santa Monica, Ca. 90405
    Next time rent it for a week before buying it!
    mertechperformance likes this.
  3. Ironball
    Ironball New Member
    ONTARIO cANADA
    there is one in every crowd...thanks for the suggestion munpot42 ....
    PLSPUSH likes this.
  4. bisco
    52,091
    welcome! why not take it to an upholstery shoppe and see what they have to offer?
  5. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    It kind of depends on what you want to do, and how much time/money/effort you might want to throw at the problem.
    I kind of recommend easiest possible solution first...then you can escalate if necessary.
    So I would start out just trying some of the many, many cushions, back cushions and other products you can buy.
    If you're lucky, you'll find one or a combination that works.
    I guess I'm lucky. The Prius seats don't bother me.
  6. mertechperformance
    mertechperformance Active Member
    532
    126
    Nor-caL
    Me neither and I've done many many MANY 12 hour plus days in the saddle.
    InPriusLove likes this.
  7. sph101
    sph101 Prius 4
    156
    92
    32
    Brevard, NC
    2018 Prius
    What has worked for me is a descent lumbar pillow and leaning the seat back a couple of clicks. When I bought my first C in 2012 I started to have back problems and found this solution now I am fine.
  8. Munpot42
    1,391
    544
    Hey I made the same mistake years ago with my new 98 Camry, took me three years of pain to finally break the seats in...so now I drive any car I'm thinking of buying a lot before committing, I wasn't being flippant, just speaking from hard won experience.
  9. spyderx
    spyderx Member
    151
    31
    MD, DC
    2014 Prius c
    its better than Corolla seat...
    no, there is no aftermarket seat bracket aside from a custom set...
    that with a aftermarket Recaro seat would be the Bomb!
  10. Ironball
    Ironball New Member
    ONTARIO cANADA
    looks like a trip to the upholstery shop next week!
  11. mertechperformance
    532
    126
    Nor-caL
    Same nice memory foam or nice gel could do wonders.
  12. Ironball
    Ironball New Member
    ONTARIO cANADA
    ok...took the seat apart and added some high density foam and made a lumbar support using the same foam,,,way better comfort and was easy to do,,,took me longer to put those silly plastic retain clips holding the battery cover on then fixing the seat...cheers
  13. bisco
    52,091
    did you see the guy who swapped his for a bmw f20?
  14. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    A member put a Recaro seat in their gen 3 also. But gave up the side air bag for seat comfort.
  15. mertechperformance
    532
    126
    Nor-caL
    I'm actually VERY interested in getting aqua G's edition seats. VERY sporty looking! [​IMG]
  16. spyderx
    spyderx Member
    151
    31
    MD, DC
    2014 Prius c
    a minor update to this topic.
    So, I've been in the process of trying to fit a Recaro seat out of a Evo VIII into my C2 for sometime now...
    And, today I was able to defeat the front driver side airbag dash light! It didn't work the first time I tried many months ago but I guess it just needed a firm push. I'm talking about a group of resistors in parallel to read 2.5 ohms simulating the resistance load of the seat airbag sensor...
    Yea, it no longer lights up w/ the resistors plug!
    Next, I'll be fitting the Recaro onto a universal seat bracket w/ height adjustments from Caribou seat company... I'll first size this bracket to the driver seat floor bolt positions... Keep you posted!
    RobAustin likes this.
