Best Tire pressure for prius
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by suirp91257, Sep 20, 2010.
  1. qdllc
    qdllc Senior Member
    1,377
    400
    I rotate left to right every 10,000 miles. I've heard it's not all that useful as compared to front/rear rotation, but I don't believe it hurts that much either.
  2. frodoz737
    frodoz737 Top Wrench
    4,719
    2,517
    33
    So...do you still have your factory OEMs installed, bought OEM replacements, ???? Actually cross rotating, with or without the spare, actually does increase tire life if you're not spot on maintaining the suspension, brakes, bearings, half shafts, steering, ect...using non-directional's.
  3. bisco
    52,341
    i did too. what made me ask was cycle's position that cross rotting reduces tyre noise.
    Merged bisco...
    when 'radial' tyres first came out, they said that they 'set themselves in one direction', and it would be bad to reverse them. that thinking seems to have hung on.
    #23 bisco, Dec 10, 2015
  4. frodoz737
    4,719
    2,517
    33
    If the radials are non-directionals you can cross...and it will reduce noise somewhat...if you have irregular wear for cause.
  5. bisco
    52,341
    maybe from not rotating often enough.:oops:
  6. frodoz737
    4,719
    2,517
    33
    That, not balancing and/or not having alignment maintained. For some reason, many Prius owners think these items don't have to be dealt with...like every other car on the road. Ever wonder why the "free maintenance" offered by Toyota and others is only 2 oil/filter changes, 5 inspections and 5 rotations?
    Sorry, forgot the Prius is indestructible and requires no maintenance.
  7. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    I know it's NOT exciting.
    I think people like the idea that they are doing something that allows them a unsanctioned advantage.
    But I run my tires at exactly the recommended PSI on the door jam.
    My observation is I really didn't see a significant MPG increase during the experimental times I tried running at a higher pressure.
    And my thought is since I am driving a hybrid that has regenerative brakes, a IMO very tricky and potentially over reactive traction control system, I don't really want to mess with how the suspension interacts with the tires and road. This is a case, where I think the complication of the Hybrid system really makes being conservative the right move.
    In other words, maxing out your tire PSI "might" give you a few MPG advantage, but my fear is the bumpy and unstable ride could be a safety hazard, more so with regenerative brakes and The Prius HSD system than with a normal car.
    But I also know I'm not going to convince those that see an advantage and think it's worth it.
    Pijoto likes this.
  8. Mendel Leisk
    41,855
    Yeah, OEM tires still. Car built in Aug 09, purchased Nov 10. Tires are Michelin Pilot MX MXM4, non-directional pretty sure. Tires were manufactured Feb 09, getting on age wise, but uniform looking tread, and around 6~7/32" tread depth remaining , only around 57000 km on odometer.
  9. frodoz737
    4,719
    2,517
    33
    ...and no dry rot?
  10. Jwservant
    Jwservant Junior Member
    Santa Cruz
    I have always used what is stuck in the door jam for tire pressures,because manufacturers don't make tires.So if you go with what is stamped on the tire info sticker in left door jam you usually are fine,plus or minus according to comfort and mileage.
  11. Mendel Leisk
    41,855
    They're pretty good still. Stacked in the garage through winter, covered in a kosher tire shroud, 15" Michelin X-Ice on the car. They're starting to crack a bit, but still pretty fine stuff. I'm intending to run them one more spring/summer/fall.
  12. tv4fish
    tv4fish Member
    202
    46
    Just my $0.02 here - I am on my second Prius - 1st was a 2005 - current one is a 2010. I found on both vehicles that when I increased the tire pressure (front from 36 to 40 and back from 34 to 38, I DID experience an increase of about 2 mpg. You definitely have to keep "air temperature" in mind as that also will affect the mpg. Regarding any negative impact on the rest of the suspension items due to this small change - I'm not convinced that difference in tire pressure IS going to cause any issues.
    skirmish and Pijoto like this.
  13. frodoz737
    4,719
    2,517
    33
    Good to hear and thanks again for you valuable guidance before buying my first snows.
  14. socal13
    socal13 livin in the foothills...
    267
    Altadena CA
    One potential problem with inflating your tires to door jamb pressure is that unless you are very diligent in monitoring your pressure you will be under inflated much of the time as all tires lose air over time which of course causes undue tire wear, handling problems, etc. The vast majority of tires on the road are under inflated due to driver negligence. Therefore keeping your tires at least 2 lb above the door jamb pressure will protect your tires.
    snead_c and Pijoto like this.
  15. socal13
    267
    Altadena CA
    Per the owner's manual, the Prius tires are supposed to be rotated front to back, same side; but for my 2015 Avalon the manual says to rotate in the cross pattern. Anyone know why these two Toyotas should have differing rotation pattern recommendations? I'm going to start a new thread with this question so as to get more responses.
    #35 socal13, Dec 14, 2015
  16. Mendel Leisk
    41,855
    I've wondered that too. I notice in the 2016 Prius Owner's Manual (available at Toyota Tech Info site now) they continue with the keep the tires on the same side protocol. There's mention of a model with full size spare (tantalizing, eh?), and even with this one they adhere to keeping rotation to the same side:
    I've stuck with the Toyota directive, kept my tires on the same side, but I'm not sure there's a point. My snows are directional. But not the OEM's. One advantage: all the curb rash tends to be on two of the rim, lol.
  17. miamiflash
    miamiflash Junior Member
    I'm on my second Prius, now. The first, a 2005, I followed recommendations found here and kept the tire pressure at 42/40. I've owned the 2016 Prius 2 for about 6 months, now, and am wondering if the tire pressure recommendation changes. Thoughts?
  18. bisco
    52,341
    haven't read any reason to change it, other than personal desire/beliefs.
  19. Coast Cruiser
    Coast Cruiser Senior Member
    2,267
    2,571
    Pacific Coast Highway
    Just make sure you have a good dentist. :ROFLMAO:
  20. AliPK
    AliPK Member
    71
    30
    Pakistan
    Toyota lists almost same pressure for prius and prius C while both having big weight difference which does not make sense.toyota recomanded tyre pressure is almost under inflated.38 to 42 seems decent range.
