Keep going with a dead 12v battery?
Discussion in 'Newbie Forum' started by Alejandro Brambila, Nov 7, 2012.
  1. Alejandro Brambila
    Alejandro Brambila New Member
    Hey everyone,
    My 12V battery is pretty much toast. When I turn the car off I can't start it again without jumping off another car. Once it's started though, it runs just fine... until I turn it off again. I realize that the jump is just switching on all the computers, but then once the other vehicle is connected what is powering all the computers in the 12V system? The 12V battery is still dead because when I turn the car off I can't turn it on again. I know there's no alternator... I'm wondering because I won't get a new battery for another week or so in the mail, and I don't know whether it's messing something up to drive around after jumping the car. Is it ok to rely on the car once it's on to drive continuously? Can I just start the car off a jump for the next week and then drive around like normal, or is there going to be a point where the 12V system shuts down in the middle of driving, shutting down the computers and the whole car? It seems safe, I've driven upwards of an hour so far once I jump the car, I just want to be sure. Don't want to be stranded somewhere with a broken car.
    Thanks for the help, (this is my first post on prius chat!)
    -Alejandro
  2. JimboPalmer
    12,470
    6,877
    Greenwood MS USA
    Do not put off installing the new battery once it gets there. If you get the jumper cables wrong it can cost you $3500USD.
  3. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    Welcome. The answer to your question is the traction battery. Yes, you can continue to operate the car like this for as long as you want. The only downside, like Jimbo said, is if you switch the polarity of the jumper cables you'll drop a pile of cash to replace everything that shorted out.
  4. jadziasman
    jadziasman Prius owner emeritus
    1,355
    488
    District 6
    To be even more precise, the DC-DC inverter converts the traction battery high DC voltage to 12VDC so all systems that use 12V will have it as long as the traction battery is charged by the gas engine and the DC-DC converter keeps working.
    Why aren't you buying a replacement battery, Alejandro? Seems awfully inconvenient to need to jump start the Prius all the time.
  5. Deja
    Deja New Member
    Johnston,RI
    2002 Prius
    Hi im having the same problem and idk what to do this is my very first car and im getting worried . im certain my 12v battery is dead. Once jumped its fine. Until turning off again .
    Where can i get a new 12v battery ? About how much are they? Should i have a mechanic install it ? Please help
  6. bisco
    51,784
    welcome! dealer, on line or auto parts store. it's certainly easy enough to install it yourself, but if you don't want to, go ahead and have them do it. batteries are around $150. - $200., and install anywhere from $50. - $200. toyota will run $3-400., installed. all the best!(y)
    #6 bisco, Dec 11, 2015
  7. Deja
    Deja New Member
    Johnston,RI
    2002 Prius
    Do you know about how much they are ?? And what kind of dealer ? Specifically a TOYOTA dealer ?
  8. bisco
    51,784
    see my edit.^^^
  9. Deja
    Deja New Member
    Johnston,RI
    2002 Prius
    Thank you! And are there different types of 12v batteries ? Does my 2002 need a specific 12v battery ?
  10. bisco
    51,784
    yes, a specific type. if you don't want oem, you'll have to search the gen I forum for alternatives, i'm not familiar.
  11. Deja
    Deja New Member
    Johnston,RI
    2002 Prius
    Ok thank you
    How do i make my own post / thread ?
    #11 Deja, Dec 11, 2015
  12. bisco
    51,784
    go to the forum main page. find the gen 1 forum in small print on the first of the gen 2 forums. click on it, then see the 'post new thread' in the upper right.
  13. Mendel Leisk
    41,215
    It'd need to be a Toyota dealership. Though, you might check 3rd party auto parts retailers too: I needed to pick up a Honda battery night before last, and Canadian Tire's Motomaster branded battery was an exact match for the Honda battery we pulled out, apart from the label. They had a very sweet battery analyzer tool on hand, tested it for me, no problem.
  14. bisco
    51,784
    also, if you search '12 volt battery' in that forum, a ton of threads come up.
  15. sillylilwabbit
    sillylilwabbit Active Member
    405
    118
    Los Angeles
    2014 Prius Plug-in
    I don't know where you are located or if all Toyota dealers (or regional) are the same price, but I was given an advertisement that says to come to the dealer and get my battery replaced with a Trustart battery for $149 installed.
    I am in California.
  16. Deja
    Deja New Member
    Johnston,RI
    2002 Prius
    Thank you ! Has your car been ok since you've gotten your new battery ??
  17. sillylilwabbit
    405
    118
    Los Angeles
    2014 Prius Plug-in
    I didn't take advantage of it because I seem to have an "ok" battery.
    I don't know how long these batteries are suppose to last. I assume 5 years? My battery is 3 1/2 years old.
  18. southtxprius
    southtxprius Junior Member
    78
    South TX
    I've heard 5 years or so. The 12V battery in my 2010 has a date code of 140111W (Jan 14, 2011). I just had the 90K service done and the dealer said the battery is fine, but I don't expect to get more than another year out of this battery.
  19. bisco
    51,784
    depends on your climate, how long it sits idle, and how many times it's been drained. i expect to get 8 years out of mine, like i did on my '04 and '08.
  20. southtxprius
    78
    South TX
    Good to know! Maybe this one will last awhile...
