Hardwire Valentine 1 via Overhead Console?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by prius3rdgen, Dec 13, 2015.
  1. prius3rdgen
    prius3rdgen New Member
    Vermont
    Hello,
    Longtime lurker, first time poster. I have a 2010 Prius IV (with the Homelink mirror, no sunroof) and I was wondering if anyone had any advice in order to hardwire a V1 using the overhead console? I own a 2011 Avalon as well and completed this mod a few years ago but I cannot recall the specific wire(s) I used. I do remember that with the Avalon I popped out the map light console, tapped into a wire, and ground it using a screw.
    Essentially what I am looking for is: which wire (that turns on/off with the ignition) should I tap into? Also, what is the procedure for removing the overhead console?
    Thank you!
  2. frodoz737
    frodoz737 Top Wrench
    4,625
    2,483
    33
    Can't help you with the wiring right now, but here's for removing the O/H.
  3. prius3rdgen
    Vermont
    Thank you! Does anyone have any advice on which accessory wire in the overhead console to tap into?
    Does anyone have any advice on which wire to tap into in the overhead console? I don't have a moonroof if that provides any additional information.
  4. scrappy
    scrappy Active Member
    125
    308
    Orange County, CA
    2014 Prius Plug-in
  5. prius3rdgen
    Vermont
    scrappy, is the red #20 a switched 12V wire?
  6. scrappy
    125
    308
    Orange County, CA
    2014 Prius Plug-in
  7. prius3rdgen
    Vermont
    scrappy, how do I test for continuity? Could you post a link or maybe a video on how to do this? Thanks!
  8. StarCaller
    StarCaller Senior Member
    1,274
    726
    Cedar Crest, NM, USA
    maybe you should just hire someone to put it in? ;-)
    BION
    StarCaller
