Snow car
Discussion in 'Prius v Main Forum' started by Joe Fisher, Dec 23, 2015.
  1. Joe Fisher
    Joe Fisher Junior Member
    44
    Kalispell, Montana
    2015 Prius v wagon
    I went to a staff Christmas party tonight. The house is way up on top of a mountain, the road is narrow and steep
    It's been snowing heavily the past few days. The tc came on quite a bit. My concern was not so much that I'd lose traction, but that the car would go crooked and plow into a snowbank.
    None of that happened, the v performed like a champ!
  2. Air_Boss
    Air_Boss Senior Member
    4,224
    1,188
    New Yawk
    Winter driving is all about technique and tires. You aced it!
    Merry Christmas.
  3. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    Last February the snow here in the North East was horrendous, and I needed to visit friends who live at the top of a ½ mile private road - the only way for me to get to their house was to turn the car around at the bottom of the hill and go up in reverse. ;)
  4. bisco
    52,386
    does your 2015 v have a 'traction off' button by your left knee?
  5. Matt73
    Matt73 Junior Member
    24
    Maryland, USA
    Glad to hear your car performed well...
    If anything, your posts suggests that the traction control disable button that appears to be in newer Prius models (including mine) isn't likely to be used very often, if at all. Which is really the way it should be, you shouldn't need it unless the TC starts misbehaving (which it sometimes, but rarely, did in my old gen2).
  6. rjparker
    10,503
    6,593
    If you were really stuck in the mud and could not move, disabling the TC might help. I keep the "secret" no button instructions in the car. Traction control procedure | PriusChat Some say it's not good for the transaxle for an extended time. Perhaps the new cars have enforced a time limit.
  7. Joe Fisher
    44
    Kalispell, Montana
    2015 Prius v wagon
    I wasn't stuck, I just mean the TC light was flashing a fair amt. on the dash. I've driven in NW Montana winters for 40 years, so I've had a chance to build up some snow driving techniques.:)
  8. Matt73
    24
    Maryland, USA
    I 100% agree that it can be helpful from time to time.. just rarely.
    As for time limits, the manual implies they have a speed limit, it will auto-enable after you get moving again, but doesn't suggest a time limit. The speed limit bit actually makes good sense to me anyway. If you've managed to get up to 25mph or so, you shouldn't need the TC disabled anymore. Unless you're trying to rally race a Prius, in which case you might need your head examined :)
  9. rdgrimes
    rdgrimes Senior Member
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    I was having a hell of a time getting moving today in a couple inches of fresh snow. Sliding around and TC light flashing all the time. :(
    Then I noticed that the parking brake was on. Released that and took off like a shot. :)
    Matt73 likes this.
  10. Mendel Leisk
    41,898
    Much as second gen Traction Control can be over reactive, I'd be really catious about putting the car in Inspection Mode: it's NOT recommended for driving the car normally, and transmission damage can occur.
  11. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    When the snow is deep enough the car compresses it, your gas mileage suffers. 35 MPG, worst tank ever.
  12. Mendel Leisk
    41,898
    An inch or two more, and your mpg goes to zero. :ROFLMAO:
  13. frodoz737
    frodoz737 Top Wrench
    4,720
    2,517
    33
    Did it with my 2010 LB last blizzard and no problems. Would I go 70 mph...no, but I would not go that fast in 8" of snow anyway. It's only for when you are or likely to get stuck.
  14. Mendel Leisk
    41,898
    We don't get much snow here, so mostly from what I've read: traction control is pretty good on 3rd generation. The logic is there's no point in spinning a wheel, better to back off and re-apply, and the computers do it pretty good, better than you could do yourself. Whether that works in practice I do not know, but isn't TC designed to help?
    Think Smart » Blog Archive » Does the Prius do Snow?
    Interesting video down the page, someone navigating up a driveway slope, the TC constantly engaging. Seems to work.
    WilDavis likes this.
  15. Air_Boss
    4,224
    1,188
    New Yawk
    I really don't understand the Prius v TC 'slam'. In my experience it works as expected, very well, from a stop in snow and ice, right on up to highway speeds.
  16. frodoz737
    4,720
    2,517
    33
    When you loose all power to the wheels you understand why "bypassing" or "switching off" Traction Control is required. Snow tires and chains cover most situations (if you have them)...but not all. :)
    #16 frodoz737, Dec 23, 2015
    golfhorn likes this.
  17. Offline
    Offline Active Member
    646
    240
    Lenexa, Kansas
    It's about snow depth and density and whether the snow is on top of a layer of ice. Getting out of a snow or ice rut can require rocking a vehicle backward and forward and using wheel spin.
    Every other vehicle we have bought that had Traction Control (all were Toyota or Lexus) had an Off switch. We knew from experience about the importance of being able to turn traction control off but it never crossed our minds that the Prius v wouldn't have an Off button.
    I've occasionally forgotten to turn traction control off when trying to rock a vehicle out of a snow rut or drift. A couple of years ago I had several people pushing and pushing in the company parking lot trying to get me moving with zero success. When I finally (DUH!) remembered to turn traction control off, the car shot away like a rocket. On that memorable day, I must have had to turn traction control off and on 100+ times during my search for streets that weren't blocked by abandoned vehicles including city buses. It was just me and the snow plows and a few other vehicles that had "real" snow tires.
  18. bisco
    52,386
    must be why they added the 'off switch' in 2015.
    frodoz737 likes this.
  19. Tideland Prius
    16,615
    On slippery surfaces such as ice or polished compact (hard packed) snow, you will want traction control as it can minutely adjust the power vs. wheel slippage to give maximum traction to move forward or backwards. In loose snow, sometimes you want traction control off because you actually do want to spin the tires and move some of that loose snow around to get to the harder pack snow or just to get out of the rut.
    So it really depends on the situation. (Just like how ABS works better in most cases but in one specific case like braking on loose snow, it's actually better without ABS and to have the wheels lock up and let the snow pile up in front of your wheels to help slow you down).
  20. frodoz737
    4,720
    2,517
    33
    I do know that when your driving on Texas ice you are going no where with traction control. Almost had a semi run up my -ss once on an up hill turning on-ramp because I (the Prius) had absolutely no power to the wheels and he was doing just fine.
