Caution: Load Carry Capacity Reduced
Discussion in 'Gen 3 Prius Main Forum' started by sillylilwabbit, Dec 24, 2015.
  1. sillylilwabbit
    sillylilwabbit Active Member
    405
    118
    Los Angeles
    2014 Prius Plug-in
    As the title states: "Caution: Load Carry Capacity Reduced"
    What does that mean? While looking at my car (driver side door where the VIN is located), I found a sticker that does not look like OEM or someone placed that sticker there.
    Was my car modified AFTER it came out of the factory? Something added that was 8 pounds?
    I purchased my car preowned. It was originally from the state of Maine.
    If it matters, the car is a 2012 Prius Plug In.
    iPhone ?
    ****Edit: never mind, I have found the answer. I guess, this post has become a FYI post.
    Seems as everyone might be different as far as weight.
    "This notice is being sent to you in accordance with the requirements of the National Traffic and Motor Vehicle Safety Act. Gulf States Toyota, Inc. has decided that your vehicle (VIN listed above) fails to conform to a provision of the Federal Motor Vehicle Safety Standards (FMVSS) No. 110 as it relates to Load Carrying Capacity Modification (Addendum) Labels."
    http://www-odi.nhtsa.dot.gov/acms/cs/jaxrs/download/doc/ACM14432945/RCONL-10V035-0123.pdf
    #1 sillylilwabbit, Dec 24, 2015
  2. BZzap!
    BZzap! Senior Member
    1,607
    878
    It seems to me that this might have something to do with dealer added equipment i.e. Sun roof. CYA might be the case. Eight pounds might be a little more critical for aircraft take-off weight maximum, but a Prius... Com'on!
  3. bisco
    52,393
    maybe because the pip is heavier than the lift back?
  4. StarCaller
    StarCaller Senior Member
    1,279
    730
    Cedar Crest, NM, USA
    I have the same sticker & stupidly it says '0'
    BION
    StarCaller
  5. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    The sticker is applied when "port installed options" are installed. The options increase the weight, making the OEM sticker wrong. They have to correct that to be legal. The law is an a$$, but the law IS the law!
    Robert Holt likes this.
  6. Bill the Engineer
    1,048
    2,278
    467
    At the beach in Delaware...
    Oh, I could have so much fun with a supply of these!
  7. CaliforniaBear
    CaliforniaBear Clearwater Blue Metallic
    1,180
    289
    Northern California
    I guess you'll just have to leave that other bag of groceries at the store.
  8. CR94
    CR94 Senior Member
    2,751
    1,205
    Northwestern S.C.
    My similar stupid sticker says 14 pounds. The only known possibly port-installed add-ons are window tint, a Toyota branded add-on Bluetooth system, and plastic rear bumper protector. It's hard to imagine those adding up to that much. Maybe floor mats?
  9. bisco
    52,393
    i've read that the window tint is heavier than it looks.:cool:
  10. CardiffChris
    CardiffChris Member
    94
    63
    Cardiff by the Sea, California, USA
    2014 Prius Plug-in
    The human head typically weighs between 5 and 11 lbs.
    Check under the Spare Tire.
  11. Robert Holt
    Robert Holt Senior Member
    1,313
    889
    I have same sticker on my 2012 trim level 3 hatchback that we bought new and would also like to know whether it was something added by dealer or legal requirements, or exactly what.
  12. bisco
    52,393
    my head only weighs 4.5 lbs.:oops:
  13. wjtracy
    wjtracy Senior Member
    11,371
    3,608
    Northern VA (NoVA)
    ...crash diet?
  14. Bill the Engineer
    1,048
    2,278
    467
    I take it that they topped off the gas tank when it arrived... :rolleyes:
  15. BZzap!
    1,607
    878
    Maybe it has to do with the load rating of the tires in which the car has been equipped.
  16. Patrick Wong
    18,210
    6,513
    Yes. My 2015 has that sticker, I assume this is because it has the optional brushed aluminum trim at the bottom of the doors.
  17. bisco
    52,393
    how does one go about making sure they haven't overloaded their car?
  18. szgabor
    szgabor Active Member
    994
    175
    Oceanside NY
    Also the Toyota branded mats !!! in the back for example that is about right if you have the four plus in the cargo plus cargo mesh ... those are add-ons (which I refused to pay but dealer did not bother to take out)....
  19. BZzap!
    1,607
    878
