All-wheel drive Prius might get US release...
Discussion in 'Gen 4 Prius Main Forum' started by Ashlem, Jan 9, 2016.
  1. energyandair
    energyandair Active Member
    905
    339
    Victoria BC Canada
    FWD or AWD offer better traction than FWD with the same tires in slippery conditions.
    My understanding is that this better traction plus reasonable ground clearance are the main reasons Subarus are popular in areas where slippery surfaces, steep slopes, heavy snow and/or high road centers are a concern
    Safety under slippery conditions however is more about the ability to slow down and/or stop under control. This has a lot to do with tires, Antilock Braking and Vehicle Stability Control. So far as I'm aware FWD and AWD provide no significant additional benefit.
    I haven't noticed much safety benefit from heated steering wheels in Florida, Southern California or for that matter in Canada. If its really cold, people generally need to wear gloves. Cold weather comfort for the first few miles without gloves, fair enough. Safety I think is a stretch.
  2. Tideland Prius
    16,555
    Sounds like an all weather tire could help (like the Nokian WR series). It'll cover the rare snowfall and summer driving. The disadvantage is a slight mpg loss due to the more aggressive rubber over regular all seasons.
    That's if the rear electric motor helps with regen (so the battery can be used more often because it has two MGs helping to recharge).
    There's a slight difference between Subaru's AWD system and the others. Subaru's one (For the most part) is always active. The benefit is that you get AWD all the time, in dry or in wet, and in every corner you take. The downside is fuel economy because all four wheels are being driven at the same time. Subaru has shrunk that gap in the last 2-3 years with the use of CVT and more fuel efficient engines.
    The others (like Toyota's) are on-demand types (or slip and grip). They're primarily in FWD and will send power to the rear wheels when front wheel slip is detected. The benefit is that it saves on fuel because you're in 2WD most of the time. The downside is that you don't really get the benefit of AWD unless something happens (usually on a slippery surface after the front wheel slips), so you're paying for an AWD system but not getting a full time benefit from it.
    #22 Tideland Prius, Jan 10, 2016
  3. spwolf
    spwolf Senior Member
    3,156
    440
    Eastern Europe
    Even Subaru's have on demand systems right now.
    Nevertheless, winter tire is crucial... it doesnt require any extra money over the course of next 4 years since then your summer tires are spent less. Summer tires work badly under 7c, so it does not matter if there is snow or not.
    sdtundra likes this.
  4. SwhitePC
    SwhitePC Active Member
    495
    214
    ca
    if tesla can get
    thing is when people who're in the market to buy a toyota hybrid, they don't think of highlander or the new rav4, they are thinking more of the prius...and can we all just conclude that the highlander and rav4 mpg's (not to mention their pricetag too) are quite laughable for being hybrids, might as well count them out of the equation.
    also, if tesla can engineer their Ds to give better range, maybe toyota can do it too
  5. Lucifer
    Lucifer Senior Member
    1,014
    486
    Nh
    All wheel drive is much safer on wet roads, like anywhere in the south year round, and I agree going isn't the problem it's stopping, studs on snow.
  6. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    Only for folks who can't do math. a hybrid Highlander or RAV4 is likely to save more gas in a year than a Prius vs the Corolla.
    TonyWilkey likes this.
  7. royrose
    royrose Senior Member
    1,389
    953
    Foot of Pikes Peak
    I believe that you can turn off traction control in the new Prius. The 4WD system, however, is an on demand system, always "on" but not actually in use unless slip is detected. The rear electric motor may also be used for initial acceleration.
    I would like to see a real world test of the E-Four Prius in Japan including acceleration times and fuel efficiency.
  8. Trollbait
    12,534
    If Toyota used a serial only hybrid, then AWD might improve fuel economy. As it is, the RXh has a slightly lower MPG rating with AWD.
  9. energyandair
    905
    339
    Victoria BC Canada
    Why is AWD much safer on wet roads?
    I heard such opinions but I've never seen either a rationale or any evidence to support such opinions.
  10. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    The -Subaru- AWD system is safer on wet or icy roads, but most others are not. The Subaru system will apply more power to the outside wheels in a turn, actually forcing the car around the corner.
    The E-AWD used in the Highlander, Rav4, and new Prius, doesn't do this. It only comes into effect if the front wheels slip, and in the Prius, only at speeds below, as I recall, 37 MPH (or was it kPH?). It provides power to the rear wheels, in addition to the power already applied to the front wheels. If the front wheels are spinning, it can get you moving when you might not otherwise, but it won't add directional stability. That is the job, in these vehicles, of VSC and other systems, using individual wheel braking.
    I doubt very much there is "switch" to turn E-AWD on or off, though they could put one in if they wanted. It isn't necessary, as there is no connection of the wheels front to rear. They can turn at different rates. Left-right differences in wheel rate is handled by standard differential action. It is turned on and off automatically by the drive system, mostly controlled by speed of travel or detection of wheel slip.
    Would the Prius E-AWD be useful in winter? Sometimes. But as with many AWD vehicles, if you needed AWD to get going it may not have been a good idea to get going, as it may be too slippery to control direction of travel and stopping. As an example of this, just take note of all the 4x4s and AWD vehicles in the ditch when the weather gets really bad. They forgot to remove their Superman T- shirts! ;)
    sdtundra and DonD like this.
  11. KyleSTL
    KyleSTL Junior Member
    79
    Not even close:
    2004-2013 Chevy Silverador/GMC Sierra Hybrid
    2005-2012 Ford Escape Hybrid / Mazda Tribute /Mercury Mariner
    2006+ Toyota Highlander
    2007+ Lexus RX 400h/450h
    2008-2013 GMC Yukon / Denali Hybrid / Chevy Tahoe
    2008+ Lexus LS 600h L Hybrid
    2009 Chrysler Aspec/Dodge Durango Hybrid
    2010-2011 BMW X6 Hybrid
    2010-2011 Mercedes-Benz ML450 Hybrid
    2011+ Porsche Cayenne Hybrid/e-Hybrid
    2011-2013 Cadillac Escalade Hybrid
    2011-2015 Volkswagen Toureg Hybrid
    2014+ Acura RLX Hybrid
    2014+ Subaru XV Hybrid
    2014-2015 Infiniti Q50 Hybrid
    2014-2015 Infiniti QX60 Hybrid /Nissan Pathfinder
    2015+ Audi Q5 Hybrid
    2015+ BMW i8
    2015+ Lexus NX 300h
    2015 Porsche 918
    2016 BMW X5 Hybrid
    2016 Toyota Rav4
    There are many of them, from convention hybrids, to plugins, from 2-seater sportscars to full size trucks and SUVs. Would be nothing new, not even for a dedicated hybrid platform (Porsche 918, BMW i8). It might be the most affordable 4WD hybrid (near the Subaru XV), but that would be about it.
  12. sdtundra
    sdtundra Senior Member
    1,314
    193
    Sacramento, CA
    I see this all too often. [​IMG][​IMG]
    The Rav4 AWD does have a center lock button to lock it 50/50 front to rear. Our CRV does not and the rear differential isn't strong enough to drive the car on its own anyway for more than a few feet
  13. Tideland Prius
    16,555
    Yet a Highlander Hybrid is only a few mpg behind an XV Crosstrek Hybrid despite weighing more than a tonne greater than the Crosstrek. That's pretty impressive to me. A RAV4 Hybrid gets 6 mpg more in the city than the most fuel efficient Corolla LE Eco despite weighing more and offering AWD-i. It's also barely behind the Corolla in combined mpg. As far as I'm concerned, the fact that these two SUV hybrids can improve over their gas counterpart (moreso the RAV4 than the HiHy), the better.
    You really think someone looking at a $20k Corolla is cross shopping a $30k RAh or $45k HiHy? Completely different vehicles (both in classes and in purpose).
    It really depends on the AWD system. It's a fallacy to simply say "AWD is safer on wet roads" without specifying the type of AWD system. Of course marketing will say "look at our AWD! It's fuel efficient cause you stay in 2WD but when the going gets slippery, the AWD system kicks in and power is sent to the rear wheels". Anyone who's driven a Subaru will laugh at that. They know the fuel penalty of Symmetrical AWD is worth the "safety" of permanent AWD. This means the computer is constantly calculating and constantly managing power to each wheel to ensure maximum grip. IIRC, Honda's SH-AWD works similarly.
    In the hybrid world, the only one that comes close is the SH-AWD system on the RLX Sport Hybrid. This car has one electric motor for each rear wheel and the normal/expected one up front to drive the front wheels. This system monitors the road surface (through the network of ABS/TCS/VSA) and manages power accordingly. The really clever bit is that when cornering, it can power or regen each wheel to get you around the corner in the wet or dry as safely and as quickly as possible. (This compares to braking individual wheel on conventional AWD systems like Nissan's ATTESA-AWD or Mitsu's AWC).
    So, the short of it is that the AWD can react quicker and get the car under control before slippage.
  14. energyandair
    905
    339
    Victoria BC Canada
    Thanks for the info.
    If I understood you correctly, the best of the AWDs can enable you to drive faster under slippery road conditions.
    What I'm not seeing is how this would make you safer. Unless the is a corresponding benefit in braking it seems that this would enable you to get into more trouble and thus be less safe.
  15. bwilson4web
    16,204
    <opps>
    #35 bwilson4web, Jan 12, 2016
  16. KennyGS
    KennyGS Senior Member
    1,243
    1,044
    Keystone State
    This will be too pricey for most, and the market already offers many other AWD choices at what will be competitive pricing. I'm surprised Toyota is considering it.
  17. UsedToLoveCars
    UsedToLoveCars Active Member
    448
    102
    In the Japan alps, I saw lots of crazy little cars with AWD. Basically AWD variants of any non-awd car you could think of - little hatchbacks, mini vans, wagons, etc. Think 4wd Toyota Starlets and honda odysseys.
  18. Trollbait
    12,534
    I've read that the full time AWD of the Rav4 only works up to 25mph or so. As that changed to all speeds in the latest generation?
    To clarify, it is one motor on each rear wheel of the SH-AWD Sport Hybrid. Considering the model and market segment, it is likely sold more as a performance enhancer than for safety.
    I agree that AWD can make people less safe because they can go faster without much improvement in stopping, as ABS can lead to people following another vehicle closer.
    A symmetrical AWD system can provide some benefit in slowing down. Engine and regenerative braking would be applied to all the wheels instead of just the front or rear.
  19. Tideland Prius
    16,555
    If you want to think that way ;). I would rephrase it as "the best of the AWDs will react much quicker to changing road surfaces". Whether you use that to go around a corner more quickly on a track or use it to get through the snowy intersection is your choice. :)
    Ahh, thanks for catching that. I'll fix the post.
    Trollbait likes this.
  20. fuzzy1
    10,444
    It can enable such, if that is what one wants to do. Another example of risk homeostasis or risk compensation, which has also afflicted may other safety improvements, e.g. seatbelts, airbags, ABS, stability control, etc. These features generally seem to save fewer lives than projected, likely in part because drivers become less careful.
    How you actually use it is up to you.
    Trollbait and KrPtNk like this.
