2012 Prius Plugin with 62k miles - Do I need a new 12v battery?
Discussion in 'Gen 3 Prius Main Forum' started by Rainking, Jan 14, 2016.
  1. Rainking
    Rainking Member
    162
    Johnson City, New York
    On (1 push of the power button)
    Accessory mode (2 push of the power button)
    Ready
    #1 Rainking, Jan 14, 2016
    49,488
    no pics. but any who, if ready comes on after 3 pushes, i don't think it's the 12v.
    are the brake lights on when you step on the brake pedal?
  3. WilDavis
    WilDavis Senior Member
    2,492
    2,153
    49
    Is the dome light "DIM", does the SKS system seem to work OK, have you had someone do a "Load Test" on the 12V battery? I only see broken icons to your image links! :confused:
  4. Rainking
    Rainking Member
    162
    I fixed the pictures.
  5. Randall Cooper
    Randall Cooper Junior Member
    Our 2011 prius did not last 40,000 miles about 2 years before it went dead.
  6. WilDavis
    2,492
    2,153
    49
    I replaced the 12V Aux. (or Management Battery, as the dealer calls it) on my 2009 Gen II (106,000miles) about a month ago - symptoms as described in my last post (eventually BIG RED TRIANGLE of DEATH!!), temp fix by jumping (under the hood) using BoosterPack, then off to the dealer to test/replace 12V battery. Problem solved! :)
    PS: I checked all the service records and found that battery (6+ years old) had never been replaced.
  7. bisco
    49,488
    from the pics, you need to try charging your battery. if it holds, great. if not, replace it. have you ever drained it?
  8. Rainking
    Rainking Member
    162
    No I have never drained it.
  9. bisco
    49,488
    kind of surprising, mine is like brand new.
    how do you get those screens? i've never seen them.
  10. Rainking
    Rainking Member
    162
    Push on button once, let navigation boot up, press and hold info and turn lights on and off three times then let go of the info button.
  11. bisco
    49,488
    thanks! i'll try it tomorrow. i've always wanted to compare the direct reading to the computer.
  12. sillylilwabbit
    sillylilwabbit Active Member
    405
    118
    Los Angeles
    2014 Prius Plug-in
    You are missing the load test step. That is the step that determines if you need to replace the battery or not.
    1 push: 12.5v
    2 push: 12.2v
    Load test: 11.1v (turn on headlights, full blast heater, rear defrost)
    Ready test: 14.7v
    Those are my results for a 2012 plug in w/ 37.5k miles.
    iPhone ?
  13. Rainking
    Rainking Member
    162
    Thanks. My 1 and 2 push is under 12v. Need new battery?
  14. bisco
    49,488
    no way of knowing until you try charging it. but if you'd rather just drop a few hundred bucks, go for it.
  15. Rainking
    Rainking Member
    162
    Why do I need to charge it? Doesn't the car do that?
  16. bisco
    49,488
    not really. it just maintains it. although the pip does charge it when you're plugged in, so maybe it does.
  17. Mendel Leisk
    38,726
    If that 11.7 is similar to what you'd get, measuring with a multimeter with the car shut down, that's not very good. Especially so if, as you said, you haven't accidentally drained it.
    I'd consider anything under 12.0 near dead. Try a smart charger, and then try testing with a tester that can test CCA. Thr dealership should have the latter.
  18. Rainking
    Rainking Member
    162
    Thanks! Will source a multimeter and report back.
  19. macman408
    1,179
    366
    Yeah, the nav system is not an accurate measurement tool. Although mine is a previous generation, when it read 11.5V in Accessory mode, the actual battery voltage at the terminals was 12.17V. When the car was off, it was 12.5V, which is what it has been since basically the day I got it.
    My personal feeling is "if it ain't broke, don't fix it." So wait until your car doesn't start (or starts doing weird things), and then maybe you need a new battery. I'm still on my original battery, 6 years in. On the other hand, if you can't afford to have your car not start when the battery dies (maybe because your boss will fire you for being late, or if you live in a war zone and need to be able to make a quick getaway on short notice), maybe it's worth it to you to replace it early.
    Rainking likes this.
  20. Rainking
    Rainking Member
    162
    Yea, decided to just leave it alone lol. Just saw a few post about it and thought I'd check mine.
