XS HID 4300K vs 6000K Difference
Discussion in 'Gen 3 Prius Accessories and Modifications' started by TomasV, Jan 29, 2016.
  1. TomasV
    TomasV Junior Member
    52
    Haddon Heights, NJ
    Hello everybody!
    Planning on getting an HID kit for the Prius. Now I can't decide on which ones to get, 4300K or 6000K. Would the 6000K be too blue? I'm planning on getting them from here Toyota Prius HID Xenon Headlight Package Deal - Toyota Prius HID Lights
    Also, what's an accessory wiring harness? Do I need it?
    Thanks!
    #1 TomasV, Jan 29, 2016
  2. Xterra72
    Xterra72 Senior Member
    1,437
    1,683
  3. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    4300K, it's the color temp of oem HIDs, and puts out the most usable light. 6000K might look cool, but in rainy, weather, when the roads are wet, the bluish light of the 6000K bulbs disappears into the roadway. The warmer light of 4300K provides some contrast and gives visibility on the same wet road surfaces.
    The accessory wiring harness is most likely a relay harness. Personally, I prefer using them because they bypass the factory wiring. Additionally, I use dual relay HID harnesses like this:
    http://pages.ebay.com/motors/link/?nav=item.view&id=301762244412&alt=web
    because, unlike single relay harnesses, if one relay fails, one headlight will still light.
    apt5020 and m.wynn like this.
  4. Sfcyclist
    Sfcyclist Senior Member
    1,621
    376
    SF, CA
    Another vote for 4.3k
  5. DRACO
    DRACO Member
    362
    78
    Rancho Palos Verdes, California
    2002 Prius
    Well, it depends on your wattage.
    If 35 watt system go with 4300K the color will be more OEM
    If 55 watt, the 6000K's the hue starts blue but will flush out to a clean white when fully warm. I have this on my Porsche
  6. Dylan Doxey
    Dylan Doxey Senior Member
    1,389
    3,459
    92
    I installed the XenonSupply kit on my PriusC a few years back. I didn't use the accessory wiring harness and it worked fine... most of the time. Sometimes only one of the two would light-up which would require shutting them off and back on again. I recommend using the additional accessory relay harness.
  7. Sfcyclist
    1,621
    376
    SF, CA
    My 55 watts 6k bulbs were def. blue. I don't see why that 55 watt would be as one is power and other is color temp. My guess is perhaps different manufacturer.
  8. DRACO
    DRACO Member
    362
    78
    2002 Prius
    Must be by Manufacturer thing, because. I assumed the 35 watt to be the same as my 55 watt and it turns out was definitely with a blue hue. Seller is sending me 4300K for the Prius.
    Once, photobucket comes back online, I will post the pics of each.
    +1 on the RELAY, the head light switch and connectors are taking extreme loads on start up.
    Dylan Doxey likes this.
  9. TomasV
    52
    Haddon Heights, NJ
    So the relay connects the HIDs to the battery directly, right? Would that mean I would have to switch my light off whenever I turn off the car? Or would it automatically shut off 30 seconds after I lock the car? Are we talking about 35w and 55w output from the car? Or the ballasts?
  10. DRACO
    DRACO Member
    362
    78
    2002 Prius
    Yes, directly to the battery but when powered down the relay will also shut off the lights even if left on, but you need to confirm this on your own. It works on my MIL's Gen 1.
    Either 35 or 55 watt ballast will use the same relay system.
  11. TomasV
    52
    Haddon Heights, NJ
    Understood! I guess I will try out the 35w ones without the ballast first, and if I'll run into any problems will get the relay. Thanks!
  12. StarCaller
    StarCaller Senior Member
    1,284
    733
    Cedar Crest, NM, USA
    " Kelvin and Lumens (35W)
    3000K:
    Golden Yellow (~2800 lm)
    4500K:
    Warm White (~3500 lm)
    5500K:
    Pure White (~3400 lm)
    6500K:
    Cool White (~3200 lm)
    With 55W Ballasts:
    (+20% lm) (-1000K)"
    I just switched recently to 6500k/
    before that I was using 4300k for a good year, followed by 5500k for another year/
    all of them with 55w ballasts/
    4300k & 5500k were both yellowish, the 6500k is white as white can be, without the slightest bluish tint/
    BION
    StarCaller
  13. DRACO
    DRACO Member
    362
    78
    2002 Prius
    Oh no, they all should have ballasts as that is what powers the HID bulb. The relay is the option, with or without.
  14. TomasV
    52
    Haddon Heights, NJ
    Ahhh sorry, I mistyped. I meant to say I will try it out without the relay first.
  15. DRACO
    DRACO Member
    362
    78
    2002 Prius
  16. WolfpackBill
    WolfpackBill Senior Member
    349
    500
    Lexington, NC
    I have the Retrofit Source 5000k bulbs and I think they're a perfect compromise. It's pure white, no yellows or blues and work extremely well in the rain. I use a set of Denso (Lexus) ballast with them and the performance of the lights is awesome!
  17. TomasV
    52
    Haddon Heights, NJ
    Went with 6000k. Still need to install the relay.
    DRACO likes this.
  18. DRACO
    DRACO Member
    362
    78
    2002 Prius
    Those look great :D
    TomasV and Dylan Doxey like this.
  19. xliderider
    8,140
    3,277
    Honolulu, HI
    Here's 4300K bulbs from cnlight, using 35w AC ballasts on my Camry. No blue, pure white light. Homemade dual relay 14 gauge wiring harness, powered directly off the battery:
    The projector foglights are using 2500K Nokya halogens. Provides great contrast for rainy, wet roads.
    jzchen, WolfpackBill and Xterra72 like this.
  20. TomasV
    52
    Haddon Heights, NJ
    Ok, so i had a problem that one headlight would sometimes stop working. I thought it was a power issue, so i installed the relay. Same thing with the relay happens. Any thoughts? Bad bulb?
