Anyone found a good aftermarket rear wiper?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Coqui, Jan 30, 2016.
  1. Coqui
    Coqui Junior Member
    29
    Orlando, FL
    Just what the thread says. I'm wondering if anyone has found a good aftermarket wiper. Mine are looking a little beat up and I'm thinking of just replacing the whole assembly if anyone knows of a good one. The only one I've found is the Duralast brand, I think is called.
    If not, what's the best inserts or store to buy the OEM inserts from? My local Toyota dealer is full of air heads that keep getting me the wrong parts, pretty sure I damaged one of the front wipers trying to replace the wiper blade. That part's my fault but how do you get a wrong part when you're given the full info? o_O
  2. tankyuong
    tankyuong Senior Member
    1,555
    661
    Central MO
    Walmart has the rain x brand for 12 bucks just snap on.oem quality
    Coqui likes this.
  3. Coqui
    Coqui Junior Member
    29
    Orlando, FL
    Thanks for the reply. I looked it up online and am saving the info. Since I hadn't seen that one at the auto parts store, I also decided to see if Bosch had a rear wiper that's just not in stores and they do. So for anyone interested, besides the Rain X and the Duralast, the Bosch OE Specialty Rear part number H409 should fit according to the site. Thought I'd mention it since in the other threads I'd found it didn't seem like many had been found.
  4. kc5dlo
    kc5dlo Active Member
    266
    163
    DFW TX
    2021 Prius
    I bought some Anco AR-16A wipers online. I could not find any locally. Did not try the dealership.
  5. yeldogt
    yeldogt Active Member
    810
    313
    NE
    Toyota sells the inserts. I never replace the blade on any of my Toyota/ Lexus vehicles. The OE blades and inserts are high quality and should be retained. You can get them on e-bay --- sold by online Toyota dealers.
  6. mengoni
    mengoni Junior Member
    33
    Kansas
    Rain x makes awesome wiper blades. I have found the rain x latitude to be amazingly quite while in use. Plus they coat your windshield in rain x if you have not done so already.
    I suggest using rain x washer fluid to keep your windshield fully coated all the time.
  7. WolfpackBill
    WolfpackBill Senior Member
    349
    500
    Lexington, NC
    Replacing the blade refills are easy, especially the rear one. The rubber insert can be bought at the dealer for $4 or $5 and takes about 5 minutes to replace.
  8. tankyuong
    1,555
    661
    Central MO
    $12 for refill here at dealership
  9. JC91006
    JC91006 Senior Member
    16,769
    8,567
    Trico makes the oem replacement rear wiper, just go to your local auto parts store to get it, it's around $10
  10. Former Member 68813
    3,524
    983
    US
    +1. you can find them free (after rebate) if you're patient enough.
  11. 3TimesMPG
    3TimesMPG Junior Member
    So.Cal
  12. arnettjs
    arnettjs My gas guzzler pulls my boat!
    25
    Central Texas
    Trico 16-A on Amazon for $10.99.
  13. Mendel Leisk
    41,463
    I'd still consider just getting the Toyota inserts, just the rubber bits. It's fairly easy to pop the assembly off the arm, when replacing the inserts. Be REAL careful once they're off, to lower the arms down gently.
    We're coming up on 60,000 kms with our 2010, manufactured Aug 09, have yet to replace the originals.
    eric1234 likes this.
  14. yeldogt
    810
    313
    NE
    I bought all three for under $20 -- no tax/ free ship. OE Toyota Denso inserts in a Toyota bag. I think the dealer was in LV -- use e-bay. What could be easier?
    The Denso blades are the best IMO -- why use something that cost more and is inferior.
  15. wjtracy
    wjtracy Senior Member
    11,368
    3,608
    Northern VA (NoVA)
    For Gen2 I go Amazon
  16. NewPriusOwnerArk
    NewPriusOwnerArk New Member
    Arkansas
    Duralast 16a. Pop right on. $11
  17. yeldogt
    810
    313
    NE
    I will say it again ... Get the OE Toyota inserts. The blade assembly is better .... yes ...you can get an aftermarket blade w/rubber for $11 ... and it will not be as good as the one that came on the car. They don't last as long.
    The Toyota frames will outlast the car .... I have the original ones on a 2000 Lexus that I bought new. I replaced my 2011 Prius inserts with over 100k on it for the first time last fall .. just because. I polished the windshield -- figured I would change the inserts. Order all three online and change them out some Saturday morning -- when you do the air and cabin filter.
    WolfpackBill and Mendel Leisk like this.
  18. Coqui
    Coqui Junior Member
    29
    Orlando, FL
    I get it, and I would if the frame for my OEM wipers didn't get damaged. Thanks for all the comments, using the duralast wipers right now, the rear one seems to be working great, the front ones are pretty good.
  19. yeldogt
    810
    313
    NE
    I'm seeing the whole Toyota OE blade (including insert) for 12-15 bucks ... order it with the filters so no additional shipping.
  20. Coqui
    Coqui Junior Member
    29
    Orlando, FL
    Thanks, that's a good idea. I think I'll end up doing that when I replace the wipers next. I think I'm done buying anything other then generic things like oil from the dealer, if that. They're constantly giving me the wrong thing even when I give them every single piece of info on my car and the item numbers.
    Do you recommend any specific site that sells the wipers?
