New 2012 Four Owner - Where do you put your phone?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by RockerJD, Feb 5, 2016.
  1. RockerJD
    RockerJD New Member
    Alabama
    Trying to get used to the new console and I'm having a hard time finding a place to put my phone. I usually like to leave it in a location where I can see it. Could you all tell me your favorite spot?
  2. Kramah313
    Kramah313 Active Member
    411
    326
    Dallas, TX
    I either just put it on the front seat or down in the area by the seat warmers and 12V. I also have a 2012 four, congrats!
  3. Xterra72
    Xterra72 Senior Member
    1,434
    1,681
    (y)Right here..
    apt5020 likes this.
  4. Caniac
    Caniac Active Member
    232
    164
    Happy Valley
    I got a Vano phone mount and stuck it on a vent. Works great.
  5. Starbrand
    Starbrand Senior Member
    493
    1,503
    Westmont, IL
    The iOttie One Touch 2. I have tried 5 other mounts for the past 8 years and concluded this one is the best (for me at least). The suction cup sticks to literally ANY surface and the snap-on feature makes it easy to mount and dismount with just 1 hand. I liked it so much, I bought my parents and fiance one as well.
    Might want to check this thread for more answers. Hope I was able to help!
  6. Mendel Leisk
    41,743
    I realize this is flippant, but I just leave mine in my belt holster.
    If it rings it's on the Bluetooth, all good. My only beef: that it seems to be impossible to have two phones automatically picked up on the Bluetooth, say if one or the other rings. My wife and I split the driving, both phones are "registered", but only one at a time will work.
  7. FroggyTaco
    FroggyTaco Member
    211
    59
    Paso Robles, Ca
    I typically place it the drivers door handle "pocket" (iPhone 6s w/case)
  8. RockerJD
    RockerJD New Member
    Alabama
    Great ideas! Thank you all. Mendel Leisk you may be right. In my old car (TDI Sportwagen) the bluetooth never worked correctly so I always had to have my phone handy. I appreciate the suggestions for the mounts as well. I will check those out if I do eventually need a better solution.
  9. kenichols29
    kenichols29 Active Member
    250
    109
    Mckinney, Texas
  10. Xterra72
    1,434
    1,681
    Is that mounted with 3m tape or is it clipped on??
  11. trip1027
    trip1027 Member
    106
    27
    wyoming
    SM-N920V ?
  12. Lindsi
    Lindsi Junior Member
    44
    Mishawaka, Indiana
    I've been using a CD mounted phone holder for a while...I actually just switched to a magnetic style one and I love it even more. I got it on Amazon for pretty cheap, search B01933Q120 if you wanna look at it. The previous one I had, the tightener was on the bottom and blocked a bit of the radio screen but this one is above it. I went with the magnetic one because the new Galaxy S7 put the power button a lot lower on the side, was weary but it holds great. Only downside with it is when I have it plugged in it sits vertical due to the pull of the wire.
