Front License Plate relocated
Discussion in 'Gen 3 Prius Accessories and Modifications' started by SubCode, Mar 3, 2016.
  1. SubCode
    SubCode Senior Member
    739
    1,341
    As you can see I lowered the license plate location to add a lil visual of appearing lower...after moving it to the lower bumper ...i had to plug those holes...found plastic plugs for .18 cents each...got em, painted them and plugged the holes...here you go.
    Hole Plugs - Free Shipping Available
    better pics in the sunlight tommorrow if it doesn't rain...
    better light...now..
    #1 SubCode, Mar 3, 2016
  2. apt5020
    apt5020 Senior Member
    881
    1,294
    Prius City, CA
    Nice.. You found it cheaper then my Home Depot pricing.
    #2 apt5020, Mar 4, 2016
  3. Kcdaniels
    Kcdaniels Junior Member
    I like it....much better than the stock position....
    Montgomery likes this.
  4. Sfcyclist
    Sfcyclist Senior Member
    1,621
    375
    SF, CA
    wow.. 18 cents! shipping must have been a lot? link?
  5. Starbrand
    Starbrand Senior Member
    493
    1,503
    Westmont, IL
    whoa, i guess i havent seen your car in awhile. because I like the baked black headlights on red. and didnt even know you changed your drls. (y)
  6. Burna J
    1,068
    3,337
    53
    Long Beach, CA.
  7. Topp Cat
    Topp Cat Member
    71
    66
    Relocation looks much better! Wonder if it has any effects on coolant temp & A/C under extreme conditions? Since Prius don't have a lower air scoop.
  8. SubCode
    739
    1,341
    goto widgetco.com
    order the 3/16" plastic plug
    shipping was like and handling $1.00
    Hey Chris thanks for the suggestion...and yeah it does look a whole lot better...
    #8 SubCode, Mar 4, 2016
    Burna J likes this.
  9. apt5020
    881
    1,294
    Prius City, CA
    You need to change that blue emblem to RED. It will look sharp, just an idea.
  10. SubCode
    739
    1,341
    Thanks for that..I was really thinking of just taken the plastic behind the badge off..and showing the red...and then painting the silver logo emblem to black...
    apt5020 likes this.
  11. apt5020
    881
    1,294
    Prius City, CA
    You could but you going to see the hole from the emblem. I highly don't recommend that method
  12. SubCode
    739
    1,341
    thanks..
  13. torparts
    torparts Senior Member
    417
    643
    Compton
    Why run a front plate... I have run no plates..., officers never hassle me
  14. Sfcyclist
    1,621
    375
    SF, CA
    Depends where you live. In the Bay Area, it's a big deal. Even a meter maid will give you a ticket for no front plates around here. It's used for by cameras so they enforce it around here.
    Merged.
    Shipping to my zip was 2.95.
    #14 Sfcyclist, Mar 8, 2016
  15. Topp Cat
    Topp Cat Member
    71
    66
    Read your local motor vehicle code! If it doesn't comply they can legally remove it off public road.
  16. Rebound
    Rebound Senior Member
    3,994
    2,642
    Portland, OR
    I've gotten away without a front plate on my PiP for four years, knock wood.
  17. Mendel Leisk
    40,964
    Shifting the plate is one thing; I can see that. It's actually a bit of a positive, if it puts the plate and it's bolts below and behind the first contact point: I've lost track of the number of hex head boinks we've got, from braille method parallel parkers.
    But I've got no patience for people removing their plates. That's right up there with the clever clogs that put clear plastic over them. Or wash the car and leave the plate grubby to the point of obscurity.
    Mr. F likes this.
  18. Rebound
    3,994
    2,642
    Portland, OR
    There are many states which don't issue front plates at all. It's hardly scandalous behavior.
    j12piprius likes this.
  19. Mendel Leisk
    40,964
    Yeah I know, up here Alberta's like that.
  20. Kcdaniels
    No front plate required in Florida ......
