Compact Spare for Two Eco
Discussion in 'Gen 4 Prius Accessories and Modifications' started by krousdb, Feb 9, 2016.
  1. Blizzard_Persona
    1,787
    948
    Pa.
    2023 Prius Prime
    XSE
    Can you folks pls report back with mpg stats for before and after adding a spare (plus jack, etc) to the Eco? Since we know that the spare delete was one of the bigger factors in the Eco's better mpg..
    And no I'm not forgetting the lead weighted rear wiper ;)
  2. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    Somebody mentioned the Toyota Jack. It's a incredible piece of junk. Requires enormous effort. It's strange that only Citroen had a built in Jack system.
  3. Mendel Leisk
    41,824
    Agree. With a simple design change, at the connection to the turning rod, it would work a lot better. As it is it jumps around with every revolution . Also very soft casting, quickly gets chewed up.
  4. krousdb
    krousdb NX-74205
    580
    500
    47
    Raleigh, NC
    Yes I did. The lug pattern is 5x100. If your PIP has wheels larger than 15" it probably has a 5x114 pattern.
    Merged
    The Eco comes with a jack. The 28lb spare has had no ill effects on MPG.
    #164 krousdb, Mar 15, 2016
  5. Mendel Leisk
    41,824
    If it's like third gen, 15" and 17" wheel patterns are identical, you can use either.
  6. krousdb
    krousdb NX-74205
    580
    500
    47
    Raleigh, NC
    AndyPrius1 said that his 2012 PIP has different pattern. The 16" Prius v has 5x114 according to another post I read.
  7. vince22
    vince22 Active Member
    205
    249
    califorinia
    Just added 35 lbs .( full spare tire) with my Eco no ill effects with Mpg.
  8. Blizzard_Persona
    1,787
    948
    Pa.
    2023 Prius Prime
    XSE
    Oh ok. I didnt realize the Eco would have came with a jack when it doesn't have a spare? But ok now I know. And that's surprising but Good I guess that there are no percieved mpg loss when adding the 28-35 lb spares :)
    I wonder at what point does the weight gain start affecting mpg?... Let's say you now add a rear wiper, that now only leaves you with slightly overinflated tires and a slightly lighter Li Ion battery compared to a two...
    So in essence a three at right around 27k msrp might be a solid choice for someone wanting a Li Ion battery, a spare and a rear wiper.... Pump up your tires slightly for mpg gains like an Eco plus you now also have 3 door sks and Nav, xm, etc at a very minimal mpg hit?? I can't decide. lol. Too many options...
  9. bisco
    52,286
    well done gentlemen! my wife cuts craft foam with an electric carving knife. i wonder if it would work here? not sure they even make them anymore.:cool:
    Merged
    you'll never notice the weight gain without lab condition testing.
    #169 bisco, Mar 15, 2016
    KimPrius3 likes this.
  10. I'mJp
    I'mJp Senior Member
    628
    552
    Ma, USA
    My wife just told me that we have two electric knives. Haven't seen them in 23 years. If I find one, I'll give it a try.
  11. bisco
    52,286
    thanksgiving, 1992?:p i remember when they were all the rage as Christmas presents.:oops:
  12. krousdb
    krousdb NX-74205
    580
    500
    47
    Raleigh, NC
    There are several threads in the Gen 4 Prius Fuel Economy Forum that suggest that there is a very small difference in MPG between the Two Eco and the other non Touring models. As long as you don't go for the 17" wheels, you should be fine.
  13. Mendel Leisk
    41,824
    OMG, just noticed your Fuelly number. (y)
  14. Andyprius1
    2,327
    859
    Cool CA
    My Peugeot had a terrific Jack.I'm using a 12 volt electric Jack now, I just push a button and up it goes.
  15. caefl
    caefl New Member
    florida
    Nice job on the mod!
    One question though, the donut spare for thre 2016 is supposed to be a T125/70D17. (I went and opened up a 2016 with a donut) in it. All I found on dbay is a listing for a T125/80R16. Wanted to get the correct one , bur avoid the cost of a new one from the dealer. any one have a source/? thc
  16. krousdb
    krousdb NX-74205
    580
    500
    47
    Raleigh, NC
    Mine is a T135/70R16 from a Toyota Matrix via Craigslist. As long as it has the proper 5x100 lug pattern, and the wheel diameter is close, it should not be a problem. If it came off of a Gen 2 or 3 Prius, or a late model Corolla or Matrix, it should be compatible.
  17. ETP
    2,803
    1,170
    Auburdale FL
    Thinking of removing my spare from my 2009 Touring Four and use it in my 2016 Touring Four. Any issues with doing this/lug pattern the same?
  18. I'mJp
    I'mJp Senior Member
    628
    552
    Ma, USA
    Only way to truly know, is to try it on.
    Andyprius1 likes this.
  19. Mendel Leisk
    41,824
    Outside diameter of the 09 is a little less? I believe the temp spares closely match OEM tire outside diameter.
    ETP likes this.
  20. ETP
    2,803
    1,170
    Auburdale FL
    Most likely will pull it before I trade it next month. If they complain I will put a can of spare tire in the trunk.
    KimPrius3, pjm877 and bisco like this.
