Disable interior alarm sensors?
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by stopherjones, Mar 5, 2016.
  1. stopherjones
    stopherjones New Member
    York
    have searched this forum, the manual and online but couldn't find out if you can disable the interior alarm sensors in the new 2016 Prius, and if so how? It's useful if I need to leave the dogs in the car.
    Any help much appreciated
    Chris
  2. Bill the Engineer
    1,048
    2,278
    467
    At the beach in Delaware...
    I am not sure what you are trying to accomplish. Why do you want to do this?
    Bill the Engineer
  3. frodoz737
    frodoz737 Top Wrench
    4,702
    2,501
    33
    Not sure this is something you would discuss on a public forum.
  4. bisco
    51,998
    welcome! what is an interior alarm sensor, burglar?
  5. KennyGS
    KennyGS Senior Member
    1,243
    1,044
    Keystone State
    What type of dogs are they, and what do they do when you leave them in your 2016 Prius?
  6. stopherjones
    York
    Hi all, thanks for the replies. I have a second gen Prius and there is a button below the steering wheel to turn off the interior alarm sensors (for the car / burglar / intruder alarm) when you lock and leave the car. The car is still alarmed, it just means when I need to leave my dogs in the car they don't activate the alarm if they move around.
    I assumed this would also be possible in the new generation but we couldn't work it out when I took one out to test and I couldn't find it in the online manual.
    Many thanks
    Chris
  7. bisco
    51,998
    there is no standard interior alarm, unless u/k is different. is yours 2007 an aftermarket affair?
  8. stopherjones
    York
    Found it.
    In the UK manual it describes how to turn the 'theft sensor' off when you power off the car. I'd been looking at the US manual, which doesn't seem to describe that feature so maybe I was looking in the wrong place or maybe the features are different?
    Thanks
    Chris
  9. bisco
    51,998
    different, i think. interesting that it's standard there.
  10. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    It is interesting that the Gen 2 in the UK had an interior alarm and that the Gen 4 does as well there. Here in North America, neither one does so far as I am aware.
  11. stopherjones
    York
    Yeah, I assumed that would be standard. No wonder you guys didn't know what I was going on about...
  12. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    Wow! Not only do you get an interior alarm, the passenger has their own steering wheel and pedals! <G>
    jdcollins5 likes this.
  13. stopherjones
    York
  14. Colin Jones
    Colin Jones Member
    99
    174
    Aberdeen/UK
    Business Edition
    In the gen 3 there is a button on the ceiling by the interior light to disable the internal theft sensors (UK)
  15. ETC(SS)
    7,184
    That explains much......
    We use a different security modality..... :D
    @OP: Glad you found your answer!
    Leaving pooches in cars is a hotter topic on this side of the pond (pun nearly unintended) because of our much warmer climate.
    Usually some PITA type flames people at the very mention of the practice.
    Best of luck!
  16. Hello1024
    Hello1024 New Member
    UK
    Sorry to dig up an old thread, but I have found a solution.
    The sensor is by the front interior light, in front of the glasses holder. It can be disabled by unplugging the sensor which is a 5 mins job.
    Undo the 2 screws inside the glasses holder, then remove the whole panel (clips on the four corners, use quite a bit of force with fingers - they didn't break for me). The alarm sensor is the black box covered in blue and black foam. Unplug the wire that goes to it. Reassemble.
    The alarm will still go off if you open the doors from the inside, but will no longer go off if there is movement inside the car. Should solve false alarms too. No warning lights on the dash or other side effects.
    picassopigeon likes this.
