Is there a tutorial on painting the wheels? I have a white prius so black wheels would be nice.
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Jeffrimerman, Apr 6, 2016.
  1. Jeffrimerman
    Jeffrimerman Member
    229
    45
    Pasadena
    I did some searching and see lots of posts about plasti dip. The newer stock wheels are semi gloss or gloss black right? So is there a plasti dip in semi gloss? Maybe something more permanent is better. I had an IS250 and it always irritated me that the plasti dip was so easy to mess up if you got a scratch the material can pull away. Maybe just degrease, prime, and paint? Maybe needs some light sanding to rough the surface up for better adhesion?
  2. HelloHybrid
    HelloHybrid Senior Member
    482
    1,483
    Maybe hit up @andino since he just painted his wheels orange recently, or get them powdercoated at a shop.
    Jeffrimerman and andino like this.
  3. andino
    andino Senior Member
    746
    551
    San Jose, CA
    If you want to plastidip, they also have a spray that makes it glossy. Otherwise, I recommend using wheel coating if you like the colors that are offered by that product line.
    Jeffrimerman likes this.
  4. DonDNH
    DonDNH Senior Member
    1,711
    655
    Nashua, NH
    Four Touring
    You can try these guys?
  5. Blizzard_Persona
    1,787
    948
    Pa.
    2023 Prius Prime
    XSE
  6. Kenny94945
    Kenny94945 Active Member
    859
    434
    Sausalito
    2016 Prius v wagon
    Painting...Op is right.
    Degrease, sand surface, heat the wheels to 70 degrees, paint, clear coat and polish.
    Plastic Dip, Hydro Film coating are options yet I have never done this.
    Still any option may scratch when replacing tires.
    Good luck...are neon and pastel colors back in style haha.
  7. Jeffrimerman
    Jeffrimerman Member
    229
    45
    Pasadena
    I think I'll go your first option. I wonder if there is a decent set of stock black ones with bald tires for cheap as another option.
