2005 Prius Honks Constantly After Hitting Unlock On Key Fob & More
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Reggaepanda, Apr 9, 2016.
  1. Reggaepanda
    Reggaepanda New Member
    I recently replaced the 12v battery in my 2005 Prius after discovering that the old battery was only supplying 9v and the car wouldn't start! About 1 month later, when trying to start the car, the dashboard acted strangely. The fuel gauge was flash back and forth between 1 bar and full bars and the gear symbols would flash at seemingly regular intervals. I replaced the key fob battery and that solved the problem.
    Now cut to 5 days later, I try to unlock the doors with the key fob... and the horn started honking a struggling muffled version of the normal alarm. Only the driver's door unlocked but you could hear a rhythmic clicking coming from the locks inside. It sounded like they were trying to unlock but couldn't. I couldn't start the car or stop the honking and lock clicking, so I removed the horn's fuse. It has since stopped honking and clicking, but it will not start.
    Can anyone please help me?
  2. dolj
    dolj Senior Member
    7,657
    3,868
    Wellington, New Zealand
    Check the voltage on the 12 V battery after the car has sat overnight, if it is not 12.7 or more give the battery a charge.
    Check that the connections on both the +ve and -ve poles on the 12 V battery are tight. Also check where the -ve connects to the car body (by the light) is clean and tight.
  3. bisco
    49,492
    make sure the buttons on your fob aren't stuck down.
