What average fuel consumption value have you used for the "Eco savings" screen?
Discussion in 'Gen 4 Prius Fuel Economy' started by pakitt, Apr 6, 2016.
  1. pakitt
    pakitt Senior Member
    2,173
    1,313
    Colorado
    For the ECO savings screen (described on page 128 of the user's manual), which average fuel consumption value have you used to compare the Gen4 to?
    The lifetime avg fuel consumption of your previous vehicle or some other value?
    And considering the Prius is always 5-6% optimistic (at least my gen3 is), put a lifetime average calculated value adjusted with that extra optimistic margin, to make comparison relative to each other correct (even if absolute values are optimistic)?
  2. krmcg
    2,592
    2,393
    Whittier, CA
    I never bothered with that screen or inputting the gas price. I put all of that in a spreadsheet.
  3. krousdb
    krousdb Silent Knight
    584
    500
    47
    Clearwater, Fl
    2025 Prius
    I use 56 which is the combined rating for the Two Eco.
  4. pakitt
    2,173
    1,313
    Colorado
    So you are comparing the current fuel consumption with the combined rating of the same car?
    I thought this view was meant to compare to another car.
  5. krousdb
    584
    500
    47
    Clearwater, Fl
    2025 Prius
    You can use it in any manner that you want. If you set it at the car's EPA combined value, you will be saving money if you exceed the EPA and losing money if you fall short. It makes sense to me. In April I saved around $24 IIRC using that logic. It is a quick way to see how you are doing. No calculation needed.
    Gabe Benke likes this.
