Maintenance Light inquiry..
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by HipShooter, Apr 20, 2016.
  1. HipShooter
    HipShooter New Member
    Los Angeles
    Does the maintenance light on the Prius 3 series turn on only for the oil change or to indicate that something
    else needs to be serviced?
    If so, will the Prius indicate if it's a specific issue i.e... brakes, headlights, etc.
  2. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,693
    1,738
    Bay Area
    maintenance light only turns on for oil change, it comes on every 5k but I think you can change it to 10k, I haven't messed around with it yet.
  3. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
    The light is coded to come on 5,000 miles after it was last reset. Even if you could, it would not a good idea to re-code it for 10,000 mile intervals because Toyota still recommends some service items at 5,000 mile intervals, such as tire rotations and various checks. If you register your VIN at Toyota Owner's Online, you will have a convenient source for the recommended maintenance schedule, as well as a record of any service that has been accomplished on your car. If you are a DIY-er, you can enter your own service activity in this log for a permanent record.
    juniperala likes this.
  4. bisco
    51,892
    welcome! there is a detail in your maintenance manual, with toyotas service recommendations every 5,000 miles. all the best!(y)
  5. Mendel Leisk
    41,398
    Considering it's just an odometer counter, and the maintenance intervals are either/or distance or time, I would just follow the schedule, and reset the thing whenever it pops up. Canadian cars don't have it btw.
  6. CR94
    CR94 Senior Member
    2,692
    1,173
    Northwestern S.C.
    Considering it's unaffected by anything going on with the car besides distance traveled, you can safely ignore it, or use it for anything about which you'd like to be reminded every 5000 miles. Or reset it pre-emptively at x miles, if you want to be reminded of whatever at x+5000.
  7. UMER QURESHI
    UMER QURESHI New Member
    PAKISTAN
    Hello, In my car maintenance light just blink with a beep. It is Japanese language and I can't understand the message on the screen. Please tell me what is the reason, what should I do.
  8. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    Welcome to Prius Chat (y).
    Google translator can help;).
    Take a picture of it and see what that says(y).
  9. FuelMiser
    1,349
    929
    Monument, CO
    The maintenance light will blink and go out when you are within 500 miles of the service reminder. The message probably says "Maintenance Due Soon" or similar. Once you reach the 5,000 limit since it was last reset, the light will remain on steady. Perform the scheduled maintenance. It is simply a reminder based on miles driven, not any indication that something has happened.
    UMER QURESHI likes this.
  10. UMER QURESHI
    PAKISTAN
    Thank you very much
  11. Salamander_King
    Salamander_King Senior Member
    11,016
    8,948
    New England
    I answered what the warning said on the other thread. It says "An error occurred". It is not a maintenance remainder, something bit more serious.
  12. juniperala
    juniperala Junior Member
    22
    Houston, TX
    Wow that is super helpful info! I never knew about Toyota Owner’s Online, thank you!
