Windshield Wiper 2010 Prius
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by vince177, Apr 15, 2016.
  1. vince177
    vince177 New Member
    daly city
    Hi every1
    You know Costco got those rain-x Windshield Wiper for kinda low price but this year they don't have the traditional wiper. They only have the hybrid wiper which its bigger and it won't fit the prius. How do I make it fit? or it just won't fit at all ?
  2. Mendel Leisk
    41,947
    Have you bought already, or not?
    If I every get around to changing ours, I'll just pick up the rubber blade inserts from a Toyota dealership, keep it simple.
  3. Dennis_MA
    Dennis_MA Active Member
    185
    109
    Amherst, MA
    Did the same. Stock blades are easy and work fine. Pretty reasonable on Amazon, especially with Prime.
  4. toyolover
    toyolover Member
    441
    67
    toronto, canada
    Toyota blade refill is almost the same price as the Costco wiper blades. If you use the Costco blades, you will lose the use of the wind deflector design on the driver's side. The defector is designed to press the wiper blade closer to the windshield under highway speed and thus cleans better. I learned this after using one pair of Costco blades (and I took it out after a month or two.)
