Master hybrid red triangle ,VSC, Brake, and no cruise 07Gen2
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by NortTexSalv04Prius, May 7, 2016.
  1. NortTexSalv04Prius
    NortTexSalv04Prius Active Member
    915
    115
    Okay
    I need good suggestions on what to check and do on my
    07 Gen 2 Prius odo 109450 miles
    My dashboard lights have the red triangle master hybrid /vsc and brake all on and I can still drive the
    vehicle.
    I have been rechecking my repair work however after replacing the following parts
    12v battery
    inverter pump
    coolant
    traction battery
    I am unsure how to troubleshoot my issue. I am hoping patrick or some of the more knowledge able
    pc members can help
    ty
  2. S Keith
    S Keith Senior Member
    799
    329
    AZ
    2003 Prius
    Read the codes. Options in my signature.
  3. JC91006
    JC91006 Senior Member
    16,724
    8,546
    History on the car? You have many major parts replaced at low mileage
    SM-N900P ?
  4. Patrick Wong
    18,200
    6,498
    As previously suggested, retrieve the DTC logged by the skid control ECU. Mini VCI is the best tool for that purpose.
    Or, you can continue to replace parts without knowing what the DTC is. That is not a very good problem solving approach.
  5. NortTexSalv04Prius
    915
    115
    Ty
    I replaced the 12volt battery because of failure and had it tested as well and did not pass test. The 12v battery failed from parasitic load. My MFD had shown low HV batttery condition and never went blue color again just pink. I have a scangauge 2 which has shown no confirmed DTC at this time. I made a mistake in replacing the inverter pump when not really need to do so . I am going to try another scan tool. I am also going to recheck hv battery connection and related things when I swap the toyota oem replacement. I do need a VCI setup but my mechanic at 80 dollar diag is also a option
  6. JC91006
    16,724
    8,546
    The inverter pump should have been replaced by the dealer under a recall.
    Where did the get the hv battery from?
    When did the problems start?
    What was the last thing you did?
    SM-N900P ?
  7. NortTexSalv04Prius
    915
    115
    Local toyota dealer
  8. NortTexSalv04Prius
    915
    115
    Last thing was replace coolant and change inverter pump that also came from local toyota dealer
  9. NortTexSalv04Prius
    915
    115
    Update
    I had seven obd codes read by a bosch scan tool at oreilly today
    C1242 open circuit
    C1378 capacitor com malfunction
    UG073 model control buss off
    U0123 lost comm with yaw rate sensor
    U0124 lateral accel
    U0126 steering angle sensor
    U0293 Hybrid vehicl control module
    my scan gauge 2 has a issue sorry about that. The 123 and 124 codes relate to the VSC which is sometimes problematic on Gen 2
    The VSC and Brake dash lights are sporadic and random these come and go when the vehicle has been parked.
  10. NortTexSalv04Prius
    915
    115
    I am going to remove the BCU aka battery control unit next to the contact in the HV maybe something overlooked there.
    ty
  11. goldfinger
    goldfinger Active Member
    535
    403
    Buffalo
    Cheap scan tools don't read ABS skid control codes. It's mini VCI or a garage. The codes you read might be ancillary to the real codes. A bad wheel sensor can light everything you have.
  12. NortTexSalv04Prius
    915
    115
    True that
    HOWEVER
    BOSCH OBD $300 Dollars scan tool does not seem "cheap"
  13. NortTexSalv04Prius
    915
    115
    Okay I have now done that but where do I find the repair process for those codes
  14. M in KC
    M in KC Active Member
    358
    106
    KC, MO
  15. M in KC
    358
    106
    KC, MO
    Aaa, that site I just posted may only be for the Gen 1's, be advised. You might want to check out a subscription to Toyota Techstream, your local library for a Bently or Clymers, Hanyes repair manual or pick one of them up yourself as other options.
  16. NortTexSalv04Prius
    915
    115
    FYI update
    I still have VSC /brake/ master hybrid dash lights coming on at low mph I have also recheck all my wor Need next step on codes posted
  17. NortTexSalv04Prius
    915
    115
    I do not trust VSC software at all but worried about other codes
  18. S Keith
    799
    329
    AZ
    2003 Prius
  19. Patrick Wong
    18,200
    6,498
    Absolutely.
    Also - when was the last time that the car operated correctly, and what happened to it causing its current set of problems? In general, it appears the OP's car has a communications problem between the various ECUs.
    I assume that car was in a significant accident - what part of the car was damaged, and was the vehicle wiring harness in that area carefully inspected for damage?
    Get Mini VCI so that you can be sure that you have the full list of correct codes - instead of relying upon a list of codes that were retrieved by a generic code reader easily confused by the many ECUs present in Prius. Your car has serious problems and you are wasting your time by relying on codes produced by code readers not intended for use with the Toyota hybrid system.
    #19 Patrick Wong, May 22, 2016
  20. edthefox5
    edthefox5 Senior Member
    10,096
    4,832
    Clearwater, Florida
    The scan gauge will not work properly on a Prius without it being updated to to an X Gauge by sending it in and they'll update it for $25.
    Most of your codes thrown are freq seen by the 12 volt B+ line dipping very low and all the ecu's then complain.
    Although new confirm the 12 volt battery is at least 12.4 volts.
    Buy a mini vci. or a Dxdiag module off amazon.com. That's your only hope. The vsc and brake are probably legit codes. Which tells me like Pat said the car was probably blasted and now has frame/chassis damage.
