2008 Just the Rear Spoiler (paint) oxidizing ...anyone else?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by harrybet, Oct 1, 2014.
  1. harrybet
    harrybet Junior Member
    Kamuela,Hi.
    IMG_0006.jpg View attachment 71271 View attachment 71271 2008 Rear Spoiler (paint) oxidizing ...anyone else ? Local body shop says they see it on Prius ..Plastic spoiler not paint on metal / also they think itʻs just the clear coat.
    #1 harrybet, Oct 1, 2014
  2. Patrick Wong
    18,210
    6,511
    Yes, this is happening on both my 2004 and 2007.
  3. JC91006
    JC91006 Senior Member
    16,780
    8,575
    On my red 2008 only, not on the other ones
  4. AzWxGuy
    AzWxGuy Weather Guy
    1,058
    541
    Tucson, AZ
    2021 Prius
    The fix is removal, sanding, primer, and repainting. I haven't done this yet and probably won't. I thought it was interesting that the oxidation is linear, perpendicular to the airflow. Maybe this has something to do with how the part was cast. It almost looks like what happens to regular unstabilized plastics exposed to ultraviolet radiation. The paint is sloughing off of my rear door handles also, mostly on the horizontal surfaces. The Arizona sun is exceptionally harsh.
  5. Paul Schenck
    Paul Schenck Active Member
    523
    306
    Fresno, California
    Easy and fun fix with plastic dip! Remove spray and return[​IMG]
    iPhone ?
    Mendel Leisk, srellim234 and krmcg like this.
  6. wa-chiss
    wa-chiss Member
    127
    Brownwood, Texas
    Mine is also. 2005 and the plastic panel on the hatch. I plan on removing and prepping for paint, reinstall, and waiting for a car to go through the body shop at my dealership that needs black paint so they can spray it black and clearing it.
    Better watch out, some people will want these recalled if too many are noticed fading. Lol.
  7. SWprius08
    SWprius08 SoCalprius
    170
    Los Angeles (SFV)
    I have same issue on my 2008, anyone has removal instructions for the spoiler?
  8. Bjorn45
    Bjorn45 Junior Member
    Fremont, CA
    I am having the same issue on my gold 2008 base model Prius. My spoiler paint is fading but the paint on the rest of the car is not. Clearly there is a problem with the paint, the painting process, or the spoiler materials. Even without the many people who have had this same problem, Toyota should clearly replace or repaint the spoiler on a car that has otherwise fine paint condition because they developed a faulty part. A couple of years ago, my rear door hatch button cover also started disintegrating in the heat and became hard (and cracked) in the cold, which is a problem that, apparently, many people have. I bought a Toyota with the expectation that workmanship would not be a problem. The least Toyota can do is cover the costs of repairing or replacing the components that they didn't properly test or manufacture.
  9. srellim234
    srellim234 Senior Member
    1,201
    1,694
    Laughlin, Nevada
    The spoiler paint and coating was really bad on the 2006 blue Prius we had when we bought it two years ago. I was just making sure I always kept it clean and well waxed. The money was not in the budget to really do much about it. Since the car was broadsided and totaled a few month ago I'm glad we didn't repair it.
    Fortunately our "new" red Prius doesn't have the issue. The problem on this one is the front end since the protective coating wasn't purchased by the previous owner. It has a bunch of tiny "dings" in the paint up there. At least it really isn't noticeable unless you're looking closely at the car.
  10. IDrivePrymaat
    IDrivePrymaat Junior Member
    67
    SoCal
    My blue 2005 is definitely suffering from spoiler fade.
  11. jeep2prius
    jeep2prius Reformed Jeepster
    17
    Los Angeles
  12. jeep2prius
    17
    Los Angeles
    I'm having exactly the same problems (spoiler and rear door handles) as you, AzWxGuy. For what it's worth, my Prius has also lived under hot sun and high temps in both Arizona and Southern California.
  13. jpaugustin
    jpaugustin Junior Member
    Frisco, Texas
    Same problem on my 2008 blue Prius. For a cheap fix I applied a light solvent (WD40) to a small area and let it set for a few hours. I then very carefully scrapped off the oxidation with a fresh razor blade. The original finish and shine returned with only a few small gouges where the razor blade dug into the paint. I will follow-up with touch-up paint on the few gouges. Agree with you guys above that a good continuous wax job would have been the needed ounce of prevention.
  14. gta_
    gta_ Active Member
    189
    134
    Tracy, CA
    My 07 has this same oxidation on just the rear spoiler. I have just left it be for now and am keeping an eye out for a deal on the touring spoiler in gray so I can replace it :D
  15. johnjohnchu
    johnjohnchu Active Member
    211
    104
    Had the same issue only on the re-painted rear spoilers. Eventually I just replaced it with an used spoiler that had the OEM paint..
  16. Robf15e
    Robf15e New Member
    Ca
    It isn't just a Prius issue. My Lexus RX400H 2008 has the same problem and I waxed it twice a year. The issue is the base material is different and it needs an epoxy primer applied to keep the base fibers from cracking/hazing through to the top coat. Toyota/Lexus should paint the spoilers separately with the proper primer coat. All the Lexus RX we see here in hot California have the same issue.
    johnjohnchu and bisco like this.
  17. cyberpriusII
    1,157
    1,818
    Mars Hotel
    So, the issue is -- are there any tutorials on how to remove this part?
    kris
  18. Maria T Hannigan
    Maria T Hannigan Junior Member
    Why bother with removing the spoiler? This YouTube video that shows you how to remove the oxidation with Lukat Fixit:
    Takes a little elbow grease (or use of a drill with a polisher attachment), but so much easier than removing and repainting. I'm told it's UV that causes this, so you might want to spray it afterwards with a UV protectant, and follow up with the protectant every 6 months to a year. Not that hard.
    craig glaspell likes this.
  19. srellim234
    1,201
    1,694
    Laughlin, Nevada
    There's actually no need to take the spoiler off or use a ton of elbow grease if all you are trying to do is restore the spoiler to match the rest of the car so the fading no longer shows. Our red Prius started having the problem and I just realized I hadn't posted how I fixed it. It was actually quite simple.
    After lightly wet-sanding the top of the spoiler I used blue painter's tape and newspaper to make sure no overspray would get on the window or the rest of the car. A can of Dupli-Color Perfect Match in Barcelona Red was ordered from Auto Zone. I sprayed multiple light coats on the top of the spoiler. After all, it's only the top that is fading. I followed that with a light spraying of Dupli-Color Perfect Match Clear Top Coat and the job was done, on the car, in a day. All for less than $20. A year and a half later it still looks good and I still have a half a can of each should it have to be redone in the next couple of years.
    If you're patient and careful, no one will ever notice you repainted only the top.
