Low Rolling Resistance replacement tyres (Europe)
Discussion in 'Gen 3 Prius Fuel Economy' started by Britprius, Jan 24, 2013.
  1. Maxwell61
    Maxwell61 Active Member
    393
    242
    Italy
    2024 Prius Prime
    XSE Premium
    My Nano 2 , after 36,000 km, are still in great shape, according to the tire shop and the measurement of the wear, which unfortunately i forgot. It looks they will go ahead another 35,000... the rubber will probably become too hard before the wearing....
    FinToy likes this.
  2. FinToy
    FinToy Active Member
    145
    141
    Finland
    That sounds great! Can you recommend any sites to purchase these tires online? Need shipping to Finland...
  3. Maxwell61
    393
    242
    Italy
    2024 Prius Prime
    XSE Premium
    I'm afraid you have to find out on the web who ships to Finland...
    FinToy likes this.
  4. Peeto
    Peeto Member
    123
    55
    Slovakia
    Hallo, anybody already bought 17" tires
    GOODYEAR Efficientgrip Performance 215/45 R17 91W XL MFS , please?
    They are B rated for fuel economy, and its like first time I see B rating in this category.
    thanks
  5. Peeto
    Peeto Member
    123
    55
    Slovakia
    I believe, everything is right, expect fuel economy - it is opposite. 205 is wider, so less mpg than 195, I guess.
  6. Britprius
    Britprius Senior Member
    5,194
    1,921
    Herefordshire England
    Other things come in to play "apart from wind resistance" when changing from 195's to 205's. You will often find the wider tyre of the same model has a lower rolling resistance quoted on the EU label. Carrying the same weight on a wider tyre means the load per square inch or mm is less this in turn gives less deflection of the tyre tread leading to less not more friction, and energy loss.
    I went up to 205/55/16's from the OEM 195/55/16's, and gained 3 MPG.
    The Goodyear Efficientgrip Performance tyres although having good RR, and wet grip figures I found were very poor on tread life "18,000 miles" also the very soft side walls are prone to failure. I cannot recommend these.
    John
    Peeto likes this.
  7. Peeto
    Peeto Member
    123
    55
    Slovakia
    Wow, thank you for your experience. I read somewhere here opposite tests, where wider tires has significant impact on mpg. Your results surprised me, but I believe you. So than I perhaps will keep stay on 215/45/17 and will not switch to 195/55/16 which I thought will be as good for mpg as 195/65/15. For 205/55/16 - i can not use these for Gen3, toyota does not have homologisation for these ones and police can penalty me.
  8. Peeto
    Peeto Member
    123
    55
    Slovakia
    Maybe this mid-budget ones? Looks like average tire, but with budget price = less cost per km.
    Hankook K125 Ventus Prime3 215/45 R17 91W ? rated C/B
  9. Peeto
    Peeto Member
    123
    55
    Slovakia
    Hallo, can you update please, how are your tyres performing? Someone here posted, they lasted him 30k miles /performance one/, which will be all right for B fuel rating tyre. I know, everything else is superb. thank you
  10. FinToy
    145
    141
    Finland
    Guys, how much do you think is the difference between class C and A tires? Which one would you choose and why? Which one lasts longer and provides better mileage?
    Toyo NanoEnergy 2 225/45 R17 94W XL, Class A/C, price 114,20€ (456,80€ / set)
    Hankook Ventus Prime 3 K125 225/45 R17 94W XL, Class C/A, price 78,90€ (315,60€/set)
  11. GasperG
    GasperG Senior Member
    1,169
    601
    Slovenia
    2018 Prius
    Previously I had Ecopia EP001s A/A rated tire, now I have Pirelli P1 C (rolling) rated tire, the diference is noticeable but it's hard to put in numbers, I would say at least 0.3 l/100 km diference.
    Are you sure you looking the right size? Prius comes with 215/45 R17 not 225
  12. FinToy
    145
    141
    Finland
    Sure does but 225 is much cheaper and still you can find it in A class. Thanks for the note though. Thanks also for the information about the numbers. 0,3l sounds quite big to me. It's 180 litres of fuel if the tires last for 60k killometres and it means 252€ with current petrol prices.
  13. FinToy
    145
    141
    Finland
    What comes to this, it seems you may even be right! I found this picture:
  14. GasperG
    1,169
    601
    Slovenia
    2018 Prius
    I have a feeling that not many newer EU eco tyres last 60k km, mine EP001 lasted just a litle over 30k km, that's why I made a choice for Pirelli.
    You must be sure 225 will fit with steering wheel at max level and you must also homologate new size. There is no good choice for 215 but I would choose GY efficientgrip performance XL for 98€, Conti ecocontact 5 (102 €) or Michelin Primacy 3 (110 €), sadly none of them are A rated.
  15. Peeto
    Peeto Member
    123
    55
    Slovakia
    Does still Toyo suports R17 with their NanoEnergy? Nanoenergy 2 is finished and Nanoenergy3 is producing only for R13-14-15 range, sadly for us 17" drivers. I someone has still Nanoenergy2 for 225/45/17 on stock, I think buy it, as they will not have any more. I just also canceled Hankooks from my list, as I checked a lot tests and their C rolling is really not so good/that is not why we bought Prius, right/. On the other hand, tire will last quite long with wear, so still can be good option in case of EUR optimalisation.
  16. Peeto
    Peeto Member
    123
    55
    Slovakia
    yep, they have similar wear rate. I can find GY EF performance for 90EUR.... but still is not very cheap and wear is questionable/someone posted 15k miles, others 30k+ miles/ . For RR it looks as best fuel efficient in this sizes, after a lot tests checked. I will try this one, I think in size 215/45/r17
  17. QuantumFireball
    QuantumFireball Active Member
    420
    269
    Ireland
    I've only done about 2500 km so far so it's hard to tell, and I have no real comparison with any other tyres on the same car. Grip seems good - I have pushed them hard on occasions and they have not let me down, and I have had no trouble in the wet (one of my priorities when buying tyres due to the climate here). You can see my fuel consumption in the links in my signature but it varies greatly on my EV driving ratio.
    I would not have much faith in the EU tyre label ratings - it would be also worth checking out ADAC and Auto Bild tests as they give significantly different results (I think there are some links further back in this thread).
    FinToy likes this.
  18. Peeto
    Peeto Member
    123
    55
    Slovakia
    thank you
  19. FinToy
    145
    141
    Finland
    Agree, but that's better than nothing. I'm still waiting for some better way to rate the tires but until that comes these ratings are all we got. Of course it's not that simple to calculate all the costs caused by tires since there are a lot of variables to consider...
    Great MPG, BTW. My best is 4,0l/100km at the moment but my trip to work is 37 kilometres of motorways with 120km/h speed limit. I've tried to avoid the biggest roads but still cannot get below 4,0. Cheers mate!
  20. GasperG
    1,169
    601
    Slovenia
    2018 Prius
    ... he has the Plug-in ;)
    Altrnative tire size for 17" could also be 205/50 R17, but not any cheaper than stock size.
    FinToy likes this.
