Craigslist ad advice please.
Discussion in 'Gen 2 Prius Main Forum' started by jules083, Jul 11, 2016.
  1. jules083
    jules083 New Member
    Richmond Ohio
    Found this on Craigslist, going to look at it now. Any ideas what's wrong? I'm leaving shortly to go look at it, should be there in about 3 hours.
    He (she?) texted me again and said 'I cleared an abs code for the acc sensor and all the lights turned off yesterday' in regard to the warning lights.
  2. aaroncv3
    aaroncv3 Member
    95
    51
    Yucca Valley
    i expected the next line to be "oh, and then there's the stubborn stench of death..."
    don't take the poster's word on the HV battery. if you have a code scanner, bring it. "codes cleared" seems fishy. take it for a test-drive, and push the car hard. install uber on your phone, incase you need a ride back to your car.
  3. jules083
    jules083 New Member
    Richmond Ohio
    How would I know the HV battery is going bad? If it's going bad I'm not against replacing it, only $1400. Id have $2400 in the car at that point.
  4. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    Sounds like the brake/abs/skid control might be out. That might be solved with a $40 used ECU or it could be the brake accumulator is going out ($$$$) which is not a DIY repair for most folks. Car is throwing codes, so codes need to be read to get a better understanding.
    Read this FAQ: Texas Prius Battery Replacement
    aaroncv3 likes this.
  5. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    What do you want it for?
    Looks like the seller is promoting it as nearly a parts vehicle.
    The way the seller is promoting it? I certainly wouldn't be investing into it as a vehicle I had much hope of driving very long without significant investment. The red flags are "Has definitely seen better days" and referring to it as a Hog...
    And the endorsement of the HV battery isn't promoted as being anything but it's still working.
    So for $1000 you get an HV battery that hasn't yet failed?
    I wouldn't look at this any more seriously than as a potential parts vehicle, and even then, my interest would be nearly non-existent.
  6. aaroncv3
    aaroncv3 Member
    95
    51
    Yucca Valley
    a code reader can tell you. and pushing the car hard may throw codes faster than standard prius driving. a failing battery will get low mileage. a good battery will have plenty of oomph.
    if battery was the only thing wrong, it might be worth it, but it sounds like other issues would make this a no-go for me. i would take the advice of others that have replied.
  7. bisco
    52,696
    welcome! if you have to ask? this isn't the prius for you.
    strawbrad and aaroncv3 like this.
  8. fotomoto
    5,639
    3,815
    So. Texas
    Also if the Ohio market is similar to my local one, it's probably all ready been snatched up by a prius/hybrid rebuilder.
