Replace your hatch opening switch cover before it melts
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Pasha00, Jul 29, 2016.
  1. Pasha00
    Pasha00 Junior Member
    Land of 10,000 Priuses
    Last week we got a serious heat wave here in the upper midwest! I noticed that a bunch of you living in Arizona, Texas, Florida.. ran into a problem with the release rubber melting during hotter weather. So I decided to change it before it got all nasty. I was hesitant to spend money on a new switch assembly. Turns out it's a simple cover change fix under 20 bucks. Saw it on amazon with the offset screwdriver included.
    srellim234 and JC91006 like this.
  2. JC91006
    JC91006 Senior Member
    16,815
    8,596
    What is under in amazon?
  3. Pasha00
    It was on Prime earlier, type in ' IE works hatch '
  4. JC91006
    16,815
    8,596
    Toyota should have come up with this a long time ago. I'm glad this is out in the marketplace to replace all the defective rubber at minimal costs
