A/C Compressor Failure
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by 2012PriusCUser, Aug 10, 2016.
  1. 2012PriusCUser
    2012PriusCUser New Member
    Southwester United States
    Just got back from the dealer and after 4 years and 68 plus thousand miles on my Prius C (bought brand new in 2012), they tell me my A/C compresser has failed and needs replacement along with a drier evacuate and recharge at a quote of $2550.00 parts and labor.
    Does anyone have experience with this? Does this cost sound normal? I am a little disheartened that only after four years of ownership, this repair is needed. I feel it failed before its time.
    Any thoughts or insight?
    Thanks.
  2. Mendel Leisk
    41,662
    Just curious, do you use AC always, frequently, sporadically? And where do you set the temperature?
  3. PriusC_Commuter
    PriusC_Commuter Active Member
    914
    307
    Los Angeles/ Orange County, CA
    2014 Prius Plug-in
    That's not very comforting :(
  4. fotomoto
    fotomoto Senior Member
    5,638
    3,814
    So. Texas
    Most definitely. Sorry. Another option is sourcing a used compressor and having a hybrid specialist shop that understands electric a/c's install it.
  5. 2012PriusCUser
    Mendeil Leisk, I've lived in southern Arizona for a little more than a year. During that time, my A/C was on all the time, at the lowest setting, mostly. Fotomoto, I am contacting a shop tomorrow for a quote.
    I feel it's absolutley outrageous to charge so much for an A/C repair and for the cost and the mileage on my car, I'm considering using what I would pay for the A/C repair for a down payment on a new car (non-toyota with a better warranty) plus a trade in. :/
  6. rjdriver
    rjdriver Active Member
    409
    170
    Rhode Island
    You say the AC is on all the time for the past year or so. Do you also have ECO mode on all the time?
    Also, you might find this discussion interesting. It's not a C, but apparently ridiculous dealer pricing for this repair is common. I was surprised to see one dealer was willing to negotiate a little. Just goes to show you how each service department inflates repairs costs to suit their mood.
    2011 Prius - A/C Compressor Dead | PriusChat
    #6 rjdriver, Aug 11, 2016
  7. Sean Nelson
    Sean Nelson Active Member
    421
    182
    Vancouver, BC Canada
    Just to clarify, the A/C doesn't always run when the "A/C" light is on. My understanding is that pushing the A/C button so that the light comes on is telling the HVAC system "you may use the A/C if you have to". The A/C will come on if it's needed to cool the cabin or if the system senses that there's too much humidity that might lead to fogging of the windows.
    In dry Arizona I doubt you'd see too much of the latter, but I can easily imagine the A/C running a lot to cool the cabin.
  8. PriusC_Commuter
    914
    307
    2014 Prius Plug-in
    A friend of a friend just reported their AC went out on a 4 year old Prius with 30k miles in Los Angeles with a repair bill over $2000, so it seems like it's occurring more frequently than it should on such a "reliable" car.
  9. 2012PriusCUser
    Rjdriver, I don't have ECO mode on. Rarely have. I was thinking about going outside of the dealer for the repair (which I could) but I'm afraid even if I spent half as much on the repair, that if the compressor placement is susceptible to damage, if it were to happen again, I'll be stuck in the same spot I'm in now. I make frequent mini road trips.
    #9 2012PriusCUser, Aug 15, 2016
  10. 2012PriusCUser
    I love my car. Totally reliable and never had any problems and I've driven it across the United States three times without issue. It's just this repair cost is so over the top. I wasn't expecting it. I mean, twenty-five hundred plus for an A/C repair is a bit ridiculous to me. I was expecting $800 or $1000.00 but certainly not $2550.
    Mendel Leisk and PriusC_Commuter like this.
  11. orenji
    orenji Senior Member
    5,887
    3,488
    Compressor is what is costing the most, I would look for a used one out of a low mileage car and find an A/C shop to make the repair. A/C units that are used everyday as I do, in California, even in winter have much shorter life spans then a car in New York. My last car a Subaru A/C died at 7 years old.
  12. Mendel Leisk
    41,662
    I agree. Rising parts and labour costs are approaching some sort of critical mass.
  13. Sean Nelson
    421
    182
    Is the bulk of the cost in the unit or the labour? I'm wondering if you can save money by sourcing a compressor from a wrecking yard...
  14. orenji
    5,887
    3,488
    New OEM compressor is about $1,200 you can get a used one from a wrecked car for under $150.00
  15. rjdriver
    409
    170
    Rhode Island
    If your quote is like the one in the post I linked, the compressor is the major part of the cost. If you can get an AC shop to work on your Prius, you can save quite a bit with an OEM part - Not refurbished - but New OEM. 12 month warantee. Same as Toyota will offer.
    Toyota Prius A/C Compressor from CarPartsWarehouse The linked shop doesn't appear to have one for the C. Just showing that for OEM cost illustration.
    Based on your description of how you run the AC and where you live it's a good chance your compressor is shot, but if there is even the slightest thought the dealer might be scamming you (other than the high price), it might be worth it to check the AC compressor relay before spending any money. To be able to charge someone $2500.00 for a $90.00 relay is probably very tempting if they think they can get away with it. My dealer tried to get me to change a cabin air filter I had replaced two weeks earlier. Not on the same scale as your repair, but still a scam by a dishonest service manager.
    #15 rjdriver, Aug 15, 2016
  16. Matt H
    Matt H Active Member
    164
    105
    Okinawa Japan
    2012 Aqua
    That's early for a compressor failure, but $2,500 for the proper repair of a failed compressor, using OEM parts is about right.
    Anything that fails inside the compressor sends junk through the whole system. The entire thing needs to be removed, and all of the pipes flushed. The condenser is of micro-capillary design, and can't easily be cleaned, so it's replaced. Most of the time, the evaporator and expansion valve will also need replacement.
    Replace a failed compressor without doing these steps, and it's usually another new compressor within a year...and another, and another.
    I'd call Toyota corporate, and tell them you're experience. You might get some good will out of it.
    Lastly, jumping to another brand because of a $2,500 repair bill on your Toyota?? LOL. Being in this industry for almost 30 years, I don't even know where to start.
    orenji likes this.
