P1121 part # for old coolant control valve vs. new
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Priusyipee, Aug 30, 2016.
  1. Priusyipee
    Priusyipee Active Member
    354
    269
    Upstate New York
    Just replaced the coolant control valve on my 2008 Prius. Bought the car in 2013 - the dealership supposedly billed Toyota for changing the part under warranty before I bought the car. Three years later the engine light pops up intermittently with P1121 as the diagnostic code. Part that was taken out of the car is PA6T/XT-GF35. This differs from the new part number of the replacement valve (16670-210-10).
    I am under the impression that the dealership billed Toyota for replacing a part without ever performing the service back in 2013. Any thoughts? If this is the case, and the old valve was in the car, I should get a refund, correct?
  2. JC91006
    JC91006 Senior Member
    16,835
    8,605
    In 3 years, anything can happen. Most repairs are guaranteed for 1 year.....because it can break after that
  3. Priusyipee
    354
    269
    Upstate New York
    I don't believe the part was ever changed. The old part # was the valve that was part of the recall. If it was replaced when I bought the car, why would a part that was known to have a latent defect be installed? My opinion is that the stealership billed for work that was never done.
  4. 1SteelerFan
    1SteelerFan Junior Member
    Tampa
    I changed coolant control valve and coolant on 2005 Prius and chech engine light still on why
  5. m.wynn
    m.wynn Senior Member
    684
    1,230
    Queensbury, NY
    You didn't reset the CEL or you didn't get the coolant loop filled and bled properly. Or Both.
    You can reset the CEL by disconnecting the negative battery cable from the body for a minute or so. If you haven't researched bleeding of the Gen 2 coolant loop, these vids pretty much show you how it's done. It's a tedious pain in the rear compared to most vehicles but not technically difficult.
    Engine coolant change DIY video posted | PriusChat
    JC91006 and Raytheeagle like this.
  6. JC91006
    16,835
    8,605
    There are multiple reasons for a check engine light, check your codes to see where the problem is.
    SM-N900P ?
    Raytheeagle likes this.
