Compact Spare for Two Eco
Discussion in 'Gen 4 Prius Accessories and Modifications' started by krousdb, Feb 9, 2016.
  1. KimPrius3
    KimPrius3 Member
    144
    188
    East Coast
    I have a 4 as well and want to get a spare as well. Could you please post a picture so I can see how it goes in and looks? Did you have to get a new form that fits the tire? Is there any rise in the hatch back floor section? . . . Any advice would be greatly appreciated.
  2. KimPrius3
    KimPrius3 Member
    144
    188
    East Coast
    Never mind my questions and requests for pics JP. I see them now. Thanks so very much. (y)
  3. mrbillz
    mrbillz Junior Member
    so, krousedb or anyone-
    I am getting ready to pull the trigger on the spare in a non spare trim- Still undecided re: cutting the original foam or springing for the trim 3 foam package - Only hurdle is that rolling toneau cover- I don't think the trim 3 has a place for it since it has the fabric cover rather than the roller one. So, my question is: could one use a router to carve a recess into the trim 3 foam cover, or could one raise the modified trim 4 foam high enough to be able to route a recess for the cover that would sit on top of the spare- (seems this would also serve to level the cargo area floor?) I really want to be able to carry that toneau cover hidden and protected for when I need it unexpectedly.
    For those of you with a 3 or 3 Touring, is there an open space (or a "usable" space in your rear foam where a cutout could be made for the roll-up toneau cover?
    For those following this thread, I posted the part numbers for the trim 3 foam pieces in another thread. I have since talked w/ a parts guy and looked at his exploded diagram from the Toyota parts catalog- and it looks like a simple swapout- The 3 pieces cost between $400 and $450 plus shipping - which can be over a hundred bucks depending on where you are. if you google the part numbers you will find several places selling- They seem to ship from California or ?Chicago.
    Thanks for all comments!
    BS
  4. MichelleStone
    MichelleStone Senior Member
    549
    818
    Mariposa, CA
    A router should work. Use a small diameter bit and set the router speed to its lowest setting. If you have a vacuum attachment, use it. You want to get those cut pieces from heating up and melting. Also make shallow cuts until you get a feel for it. You'll also want to create a template to keep the router from cutting where you don't want. And use a shop vac frequently to suck out the waste in your grooves. There are many ways to do that. The easiest is with a template set for the router. They don't cost a lot. The guiding template cutting piece is mounted on the router. You make a 1/8" to 1/4" inch thick plywood template and cut the sized hole you want sized just bigger than what you need (the difference between your router template guide and the cutting bit) Or you can build a barrier type from a sheet of plywood. Build up barriers with 1/2" to 1" thick wood so the router base is kept from going outside a specific region. When making this type of template, I use screws to attach the wood guides.
    Now... I've never done this on Toyota foam. So, I'm just offering advice based on my experience in cutting plastics and wood. Plastics do melt and wood can burn. The key is to not let the material stay in contact with a spinning blade.
    Howe and RCO like this.
  5. KimPrius3
    KimPrius3 Member
    144
    188
    East Coast
    I want to order a donut spare. Are there any numbers I need to use when I look for one? My Prius has 15" tires.
  6. GaryD1
    GaryD1 Active Member
    302
    138
    Seagrove, NC
    I bought 4 Gen 3 wheels and purchased tire from Sears and had it mounted. I don't ride spare around, wife ever has a problem all she has to do is call and I'll be there with full size spare. Ebay probably have some, also your local Craigslist might be an option.
    KimPrius3 and RCO like this.
  7. Dragon Rider
    Dragon Rider Active Member
    344
    212
    Miami
    I got mine from tirerack.com. a full tire for 143.00 . Rims tired . They shipping is fast too. I have it at home. They can always bring the tire to me. problem solved .
    KimPrius3 and GaryD1 like this.
  8. KimPrius3
    KimPrius3 Member
    144
    188
    East Coast
    Wanting to get a donut spare for my 4. The compact spare shown in the owner's manual (pg740) has the following written on it "T125/70D17 98M". Do you know if this will fit my 4 with 15inch wheels or does the "17" indicate that it's for a car with 17 inch wheels? I know nothing about donut spare tires, but want one before taking any long trips. Any and all advice is most welcome.
  9. Mendel Leisk
    41,521
    I'd strongly suspect there's one spare for both 15" and 17" tire equiped cars. There's only one owners manual, one spare size specd.
  10. greenmonster01
    106
    79
    Southeastern MA
  11. greenmonster01
    106
    79
    Southeastern MA
    What's in the blue (static?) bag? On my Eco the rectangular cutout was empty. Is there supposed to be and OEM item there?
  12. Dorkytom
    Dorkytom New Member
    Orange county, ca
    It looks like the blue bag contains the front license plate bracket.
  13. greenmonster01
    106
    79
    Southeastern MA
    I think I figured in out...I beleive that spot is for the bag for the cargo cover.
    4GP2ECOBP likes this.
  14. sillymike
    sillymike Junior Member
    59
    GA
    I know I am late to the party on this but I am researching doing this retro fix like you have. Can you tell me what you used to cut the styrofoam and padding underneath? Did you use a handsaw, jigsaw or a hot knife? Thanks
    plug-it-in likes this.
  15. sillymike
    59
    GA
    Which plastic screw did you order if you dont mind me asking. Thanks
  16. I'mJp
    I'mJp Senior Member
    628
    552
    Ma, USA
    here is what I bought on ebay. The pictures are long gone. $23.00
    2011 TOYOTA PRIUS OEM SPARE TIRE LOCK DOWN BOLT / CAP.
    RCO likes this.
  17. sillymike
    59
    GA
    Thank. Appresh!
    RCO likes this.
  18. plug-it-in
    plug-it-in Active Member
    179
    113
    Kitchener, ON, Canada
    Well down! Interestingly my 2016 Gen4 came with a doughnut spare. Maybe Canadian winters came into play when Toyota spectrum out the cars for here? On the other hand, while I did not have a flat in perhaps 40 years, our iMiEV has only a well hidden inflator kit. I told my wife not to bother just call CAA and have the car towed to our favored tyre shop.
    RCO likes this.
  19. Mendel Leisk
    41,521
    There's only "level" in the Canadian Prius lineup that nixes the spare, the "technology" level, with "advanced package". I just happen to have my brochure here. :whistle:
  20. plug-it-in
    179
    113
