Prius 2016 4th Generation: How to remove door panel" and my speaker install.
Discussion in 'Gen 4 Prius Audio and Electronics' started by orangebang, Sep 10, 2016.
  1. stanigu
    stanigu Member
    58
    62
    Blackhawk, CA
    When putting mine back on, I started at top--sort of "hook" onto the top rail, then snap on the clip near the mirror and go around/down from there.
  2. xerox914
    xerox914 Junior Member
    san francisco
    That what i am trying to do is from top but seem like is not hooking correctly. lol i spend few hrs now and i still cant get it hook the top rubber piece.
  3. stanigu
    stanigu Member
    58
    62
    Blackhawk, CA
    Hmm..odd. The thing almost automatically popped in for me. This might help: there are evidently some "claws" towards the top rear of the panel. So you have to hook it on at an angle, and push it in. I didn't give it much thought but it did go back on.
    NguyenCB7 likes this.
  4. xerox914
    san francisco
    finally went in!!! i have to force it in the rubber/rail slot. This panel is pretty dang hard to put back compare to others cars. Thanks !!
  5. MD Hel
    MD Hel Junior Member
    Louisiana
    I had the same problem and realized that that clip was supposed to stay on the door. If you pop it out of the door panel and then try to put the panel back on it's a lot easier.
  6. neopunk1
    neopunk1 Junior Member
    32
    SoCal
    Thanks op for this guide. I just installed the same set of 6 speakers he used. At small volume, not much difference from stock but the value is in cranking it up.
    Anyway, I am wondering if it is worth it to buy a small 4-channel amp to drive these or add a small powered sub!!!
  7. Rodrigo Frade
    Rodrigo Frade Junior Member
    Ireland
    Active
    Hi. Great thread. I am replacing my head unit but I am struggling to remove the dash. Do you have any suggestions to get around this? Thank you. R
  8. JayLn
    JayLn Active Member
    248
    141
    Four Touring
    Hoped some one will make a step by step guide with photo on how to do an amplifier hehe
  9. maxidream
    maxidream Junior Member
    24
    usa
    2019 Prius Prime
  10. Elt31987
    Elt31987 Active Member
    205
    155
    Derry, NH
    maxidream likes this.
  11. zorro18888
    zorro18888 New Member
    Singapore
    I will be upgrading my head unit to a 10.1 inch Android by end of may
    Thereafter, I will replace the stock speakers
    No additional amps for me just have the head unit (4x50x) drive the 6 speakers
    My ride comes with JBL but I have shortlisted the Infinity Reference 6532ex for the Fronts and Rears
    For the dash speakers, I will put on hold as I m not to familiar with replacing them
    I need videos as I am a visual guy
    I will be putting up videos on YT for my HU removal and replacement
    My video skills suck though
  12. Elt31987
    205
    155
    Derry, NH
    The fronts are the easiest ones. Just use a panel removal tool on the inner side of the panel to pop it up and its only 2 bolts holding the speaker in. I highly recommend getting the below adapter for the dashboard speakers so you dont need to splice.
    https://tinyurl.com/ycpat6th
    zorro18888 likes this.
  13. zorro18888
    Singapore
    Thank you
    I have ordered the redwolf speaker adapters from amz
    Elt31987 likes this.
  14. maxidream
    24
    usa
    2019 Prius Prime
  15. Elt31987
    205
    155
    Derry, NH
    Looks To be the same Kicker CS that I have
  16. zorro18888
    Singapore
    The Metre and Redwolf connectors and brackets together with the front & rear speakers (Infinity Ref 6532EX) arrived
    Now waiting for the Dasj tweeters before I stall the installation.
    Question:
    1. To remove the stock speakers, i just need to remove the rivets and the stock brackets and replace them with the Metra brackets & Infinity speakers?
    2. What about the brackets that came with the Infinity speakers? They cant be used for our ride?
  17. thomassster
    thomassster Member
    239
    83
    Colorado, US
    2019 Prius
    XLE AWD-e
    use a drill to remove the rivets. you can attempt to keep the stock bracket, but the metra brackets are a bit cleaner. If you use the stock bracket, you'll have to drill holes through it. The brackets that came with the infinity speakers don't fit well. You will do some hack job which won't give you a nice seal. I used some rivet nuts but you can attempt to use a nut and screws. It is very difficult to get a socket to hold down the nut so it won't turn. I tried that first, and I only managed to get some gloves and got it finger tight, before I went the rivet nut route.
    If you have soldering skills, you could reuse the connector on the dash speakers in place of the red wolf adapter connector. That's what I did and many folks on this forum did.
    Mambo Dave and zorro18888 like this.
  18. zorro18888
    Singapore
    You cleared all my doubts. Thank you
    Yes, I will be putting in new rivets n will use the Metra brackets.
    I eillrwill also be using the redwolf adapters on the dash speakers.
    No soldering for me.
    Thanks again
  19. zorro18888
    Singapore
    anyone know the size of the rivet nail to use when installing the metra speaker brackets?
  20. zorro18888
    Singapore
    The redwolf connecters for the tweeters does not fit the factory tweeter connectors.
    I may have to splice the speaker wires since the woofer n tweeter wires are connected together
    Anyone know know to splice the wires?
