Aftermarket wheels
Discussion in 'Gen 3 Prius Main Forum' started by Gnarly, Sep 28, 2016.
  1. Gnarly
    Gnarly Member
    142
    44
    Hey everyone,
    I see lotsa Gen3's with aftermarket wheels. Doesn't that reduce some of the fuel efficiency? I believe it could potentially lower mileage but
    I'm sure there's different camps that believe otherwise but I can't find anything about this discussion.
    If not, then can has anyone put 18's on the rear and 17's up front and stiffening the front and middle frame?
    I know that's two different questions but someone's probably inquiring the same.
    Thanks,
    Gnarly
  2. Lucifer
    Lucifer Senior Member
    1,014
    486
    Nh
    Width doesn't matter but circumference has to be within a half inch
    Ideally you would put on the lightest wheels with the smallest footprint ;) ;)
  3. Gnarly
    Gnarly Member
    142
    44
    1/2" of the OEM width?
    For example, 16x7.5 can be replaced by a lighter wheel at 16x8?
  4. Gnarly
    Gnarly Member
    142
    44
    #4 Gnarly, Sep 28, 2016
  5. Vman455
    Vman455 Senior Member
    539
    556
    The Middle
    You can put wheels of whatever diameter you can fit, but you can't have different sizes (tire diameter) on front and back without freaking out the ABS sensors.
    The more/larger the openings in the wheels, the higher the drag. The wider the wheel/tire, the higher the drag. The closer the wheel face is to the edge of the fender, the more difference in drag the wheel design makes. The further the wheel and tire stick out from the body, the higher the drag. Completely closed wheel faces over stock wheels are worth 1-1.5mpg at 50mph on a Gen 3 Prius vs. the stock wheels without wheel covers.
    TGrracie and Burna J like this.
  6. padrino
    padrino Junior Member
    Sun Diego
    What would a 16x7.5 +40 do, fit wise?
  7. Mr. F
    Mr. F Active Member
    389
    262
    Washington
    An ordinary two-way ANOVA of the raw data reveals that the direction of travel (North or South) had a significant effect on the consumption (P=0.0269), but whether or not the wheels were covered had no significant effect (P=0.3690).
    Directly comparing the means, as the experimenter did in the original post, does not account for the variations within each measurement condition and yields no useful information.
