2012 question
Discussion in 'Gen 3 Prius Technical Discussion' started by lucky1, Sep 29, 2016.
  1. lucky1
    lucky1 Member
    145
    61
    Ontario
    I own seven Prius taxi cabs and the battery in the 2010's did not hold up well because they changed the way the venting was in the battery was getting too hot and would have to replace at 300,000 km whereas the second-generation cars would still have an original battery at 700,000 km
    Does anyone know if they fixed that problem I am looking at a good price on a 2012 Prius
    Also the transaxle on the 2010 Prius did not hold up as well as the second generation Prius under the tough pounding the taxis take .
    48,996
    i have not heard of either of those being changed. but toyota is only concerned with getting past the 10/150 warranty.
  3. Aaron Vitolins
    Aaron Vitolins Senior Member
    1,612
    1,144
    Franklin TN
    I believe that 2010-2015 didn't change other than different lights, and slight styling. I had a 2012 and my best friend had a 2011, my 2012 looked much nicer but other than the nicer interior, rear lights, and front bumper, it was the same. God I love the 2nd generation. So damn tough!
  4. lucky1
    lucky1 Member
    145
    61
    Ontario
    I talked to a mechanic at Toyota last night and he said they had corrected the cooling /venting of the battery that they royally messed up in 2010 when I asked him about the 2012 and he was fairly sure they did something about the transaxle --
    The second generation were bullet proof and I was shocked when my first 2010 had the battery and transaxle issues very disappointed but love the Prius as a taxi so much I will see how the 2012 works out
  5. exstudent
    exstudent Senior Member
    2,212
    900
    Torrance, CA
    Gen3 (2010-2015) transaxles lack the weak magnetic drain plug that were standard on Gen2(2004-2009). You can always upgrade to a magnetic drain plug for the transaxle.
    Hopefully you are doing regular drain/fills on the transaxle.
  6. szgabor
    szgabor Active Member
    993
    175
    Oceanside NY
    What do you mean regular .... in this context ?
  7. ChapmanF
    15,111
    The 7" nav headunit changed from a 4-CD changer with the maps on a DVD, no HD Radio and no DVD playback, to a 1 CD/DVD player with the maps on a hard drive, HD Radio, and improved USB music navigation (can list by your Artist and Album id3 tags finally), plus a second FM antenna added on the right quarter window for better FM reception.
    Also the power button turned blue, the temperature button sprouted red and blue triangles, and the A/C and pollen-suck buttons swapped places. Who could overlook that? :)
    -Chap
  8. exstudent
    2,212
    900
    Torrance, CA
  9. Mendel Leisk
    38,254
    The trouble with this: you're working with vague conjecture from this guy. My pure guess: there's no change to battery vent method or transaxle, 2010 through 2015.
    StarCaller likes this.
  10. bisco
    48,996
    agreed. if there was, i would like to see specs, link, pics or something. isn't the gen 3 similar/same as gen 2?
  11. Mendel Leisk
    38,254
    There are some differences, I have a vague awareness: 2nd gen fan is up on the hatch wall, while 3rd gen fan is right next to battery. I believe also second gen air exhausts through some sort of snorkel,whereas third gen air just dumps into spare tire region, finds its way over to exit flaps under the bumper fairing. This is on reg 3rd gen, plugin is different again.
