Sad Day, lots of $$ repairs. Trying to save what I can. 12v Battery?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Angelo, Oct 3, 2016.
  1. Angelo
    Angelo Junior Member
    Hey guys, the sating goes when it rains it pours is true. I just moved from SoCal to Seattle. The rain season is starting and one week ago my passenger HID headlight went out, again. I already replaced it once back in California including the ballast, it has since failed again due to the ever present condensation.
    Took it to a shop to have oil changed, headlight diagnosed, and be on my way. Turns out the lamp has a leak and needs the headlamp assembly to be replaced. I wan warranty this time so I am letting the shop provide it. About $350 or so for the HID with bulb replacement. Then my 12v batter is lower than low and failed the test, even after a trickle charge no good. So now more money and more labor.
    I didn't realize how hard it was to find Prius (2008) batteries. Costco sells batteries but not for the Prius, go figure. Kragen, Autozone, O'Rileys all sell the Yellow Optima battery for $230 Plus! To save some cost and labor here, what is a reliable battery that will FIT and Connect to the existing setup? They cahrge one hour labor and their battery cost is about $165 so about $240 for the job. I would like to get a battery for around 100-120. Can this be done, how difficult is the swap procedure?
    Thanks for all the help guys, sad day for me realizing I may be $850 bucks poorer soon.
  2. andrewclaus
    andrewclaus Active Member
    993
    326
    Golden, CO
    Are you a AAA member? Several years ago AAA changed mine out for the low $100s. I'm not sure it was a very good battery, but it did the trick.
    Otherwise, $180 for a good battery is about as low as you can get. I got one for just over $200 from Toyota recently. The DIY is not too bad, a little more involved than a standard car, just some light mechanical things to remove.
  3. andrewclaus
    993
    326
    Golden, CO
  4. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    Dat Boi likes this.
  5. Stevewoods
    Stevewoods Senior Member
    659
    1,122
    Seattle, WA
    I priced a Toyota battery for my brother-in-law last spring at Broadway Toyota in Portland for $190. I would guess you could probably find a genuine Toyota battery for less than the Optima. Try looking at the Toyota dealership websites.
    There is Seattle, Lake City, the one near Edmonds -- Fife or Tacoma if you are that far south.
    Also, that stupid store, Batteries Plus has a Prius battery for around $200.
    A lot of times they have discount coupons for parts and/or service on their web sites.
    Putting in the battery is a little fussy, but no big deal. Lots of instructions on this site.
    The Batteries Plus at Northgate is quoting the Duracell for the SmartKey Prius at $195. You get 10 percent off if you order online and pickup in store.
    They offer free installation on some batteries, but I doubt that holds with the Prius, but at any rate, you get the battery for around $175,
    Maybe you can pay them $20 to get them to install. Personally, I would do it myself, but...
    #4 Stevewoods, Oct 3, 2016
  6. johnjohnchu
    johnjohnchu Active Member
    211
    104
    #5 johnjohnchu, Oct 3, 2016
  7. wjtracy
    wjtracy Senior Member
    11,365
    3,608
    Northern VA (NoVA)
    well, hard luck OP ...but I thought you were going say HV Batt died and WA does not extend to 10 yrs. like CA...so hopefully that does not happen!
  8. exstudent
    exstudent Senior Member
    2,214
    905
    Torrance, CA
    Optima is a less than ideal choice.
    Car Batteries | Pep Boys | Battery Installation | Car Service
    1) Bosch AGM is $143 vs Optima $187.
    2) Warranty: Bosch 4 yr vs Optima 3 yr.
    3) AmpHrour: Bosch 46 AmpHr vs Optima 38AmpHr. Optima looses a lot of capacitynb/c of the spiral co struction vs traditional plate construction.
    Toyota True Start AGM for Prius can be had for $160-$180, if you price shop and get the local dealer to beat or match the cheaper dealer. 7yr pro-rated warranty.
    kenoarto and johnjohnchu like this.
  9. exstudent
    2,214
    905
    Torrance, CA
    dbl post
    #7 exstudent, Oct 4, 2016
  10. exstudent
    2,214
    905
    Torrance, CA
    double post
  11. Beachbummm
    Beachbummm Senior Member
    1,160
    392
    johnjohnchu likes this.
  12. goldfinger
    goldfinger Active Member
    535
    403
    Buffalo
  13. Beachbummm
    1,160
    392
    plus the prime membership, i think its 90 bucks a year
  14. kenoarto
    kenoarto Senior Member
    398
    Chicago, IL
    FWIW: Replacing the Prius battery is a clean, grease free procedure as it is located inside the car. Takes 30-40 minutes the first time, half that the second time. A good video on youtube does it in less than 5 minutes. I always wait for a 25% off parts coupon at Toyota or Advance.
