The Hybrid Convertible Project Prius v
Discussion in 'Prius v Technical Discussion' started by Bill the Engineer, Aug 8, 2014.
Thread Status:
Not open for further replies.
  1. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,520
    Bay Area, California
    2019 Prius Prime
    On my iPhone it isn't registering. Maybe in a couple of minutes
  2. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Hum, I can see them on my iPhone, iPad & desktop
    iPhone ?
  3. Dylan Doxey
    Dylan Doxey Senior Member
    1,389
    3,459
    92
    Try a reload.
  4. gafortiby
    gafortiby Member
    97
    58
    Colorado
    I have the same problem with "content blocker" and ad blockers. try disabling them both then the pictures should show up.
    On iOS safari, you can touch and hold the reload arrow-circle and then click on reload without content blocker.
  5. Bill the Engineer
    1,048
    2,278
    467
    At the beach in Delaware...
    The morning sunshine on the Firebrid this morning.
    I took a vacation day today (Friday) and spent most of the day working on the car. The cut-out for the right a/c vent is made, and the opening for the speedometer has been raised to clear the left a/c duct. Sadly my 30+ year old scroll saw broke while working on the left a/c vent cut-out. Replacement parts are not available, so I'll be making a purchase of a new one soon.
    Then I got out the air cut-off tool and started to work on the right front fender. Things will work out nicely when I purchase the extra front fenders in the spring to splice into these. Right now it reminds me of a slide trombone.
    All things considered, it was a very good day.
    [​IMG][
    Bill the Engineer
    m.wynn, breakfast, MDNHW11 and 2 others like this.
  6. gafortiby
    gafortiby Member
    97
    58
    Colorado
    Scroll saw? Do you mean jig saw?
    Bill the Engineer likes this.
  7. bisco
    52,282
    looking good bill, you will use extra fenders to fill in the gap?
  8. Bill the Engineer
    1,048
    2,278
    467
    "WEN Model 531-Type1 Scroll Saw" written on the side of the saw. You may call it what you like, but it is so old that WEN doesn't even list it in their replacement parts section of their website. Hits on eBay call it "vintage". It is so old that the 2-prong electric plug doesn't even have one prong wider than the other.
    Actually, two OER replacement fenders (made from the original dies) will be purchased, and the filler panels will actually come off of these two fenders. That way I minimize the body rot that needs to be repaired. These two are just stand-ins to make sure everything aligns properly.
    Bill the Engineer
    Dylan Doxey likes this.
  9. gafortiby
    gafortiby Member
    97
    58
    Colorado
    Oh okay. When you said scroll saw I was trying to visualize how you could use this tool pictured below to cut the AC vents on the dash. If you want to cut custom flat objects freehand with great control, scroll saw would be it.
    If you are buying a new jigsaw be aware! Many modern jigsaw models have very poor "shoe" locking mechanisms. My Ryobi model was impossible to cut perpendicular to my surface and messed up manyy cuts. Eventually got a dewalt which works well.
    #649 gafortiby, Oct 8, 2016
    breakfast and Bill the Engineer like this.
  10. Bill the Engineer
    1,048
    2,278
    467
    Bill the Engineer
  11. Bill the Engineer
    1,048
    2,278
    467
    Interesting. Your definition of Scroll Saw and Jig Saw are exactly opposite mine. Maybe somewhere along the way the two terms were swapped by the saw manufacturers. To me, your photo is a bench-top Jig Saw. My saw shown below is a specialized saw that has a feature where you can rotate the direction of the blade while you are cutting. Alas, I now also see online that the term Sabre Saw is used for a Sawz-all, which I have always known as a Cut-off Saw. This is all making me feel old and out of touch, since I always knew a Sabre Saw as the version of my saw in the photo that didn't have the turnable blade feature.
    I'm going back up to bed. I must be having one of those jumbled-up nightmares again...
    Bill the Engineer
    #651 Bill the Engineer, Oct 8, 2016
  12. bisco
    52,282
    i used to have one, way back wen.
    gafortiby and Bill the Engineer like this.
  13. ChapmanF
    18,454
    From the label in your photo below, it seems to be new enough to be "DOUBLE INSULATED", in which case it may have been new enough that polarized plugs existed, but exempt from needing one.
    -Chap
  14. gafortiby
    gafortiby Member
    97
    58
    Colorado
    I spy a tardis. Is that from the seventies too? ;) Any chance you incorporate that into the firebrid? Actually many posts ago I recall reading you will use the tardis whoosh as the low speed pedestrian warning sound.
    I think sawz-all, cutoff saw, reciprocating saw are interchangeable terms. Never heard the term saber saw. But my reference point is woodworking, not metalworking. Although I did work a bit in a metal shop but that was in milling machines and lathes.
    My ryobi saw had that rotating blade feature too. The problem was that the blade would rotate on its own anytime I hit a hard knot in the wood because that locking mechanism did not tighten well either.
    #654 gafortiby, Oct 8, 2016
  15. San_Carlos_Jeff
    San_Carlos_Jeff Active Member
    871
    160
    Northern California
    2012 Chevy Volt
    Love this post. Having never done major body work I wasn't able to visualize the steps you are going to need to do when extending the fenders. Now it all makes sense :)
  16. MDNHW11
    MDNHW11 Junior Member
    2001 Prius
    If you did all that cutting on a single blade, then hats off to you!
  17. rdgrimes
    rdgrimes Senior Member
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    I'm waiting to see the big scoop and tunnel ram on the hood.
  18. Bill the Engineer
    1,048
    2,278
    467
    Sorry to disappoint you. It will have the smooth 326 hood (no scoops) only made longer to fit. No hood tach either, since the engine won't even be running half of the time.
    Bill the Engineer
  19. Bill the Engineer
    1,048
    2,278
    467
    Today I got the left side caught up with the right side.
    Bill the Engineer
    breakfast and San_Carlos_Jeff like this.
  20. bisco
    52,282
    wow, i can't believe you have the patience to wait until spring.
Thread Status:
