Instrument Cluster Brightness??
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by keymusic, Oct 30, 2016.
  1. keymusic
    keymusic Active Member
    205
    111
    Southern California
    I read the manual on this but it doesn't seem to be working correctly, am I doing something wrong? In my 2017 Prius 2 I normally keep the instrument cluster brightness fairly dim at night, but I want the brightness to stay bright during the day (when it's bright outside) without having to manually turn up the brightness if I put on my headlights on. It says in the manual that it does this, and it worked fine in my generation 3 Prius. Right now if I turn on my headlights or parking lights during the day in full brightness, the instrument lights dim to where I have it set for nighttime use, so I can't even see the instruments.
    Help!?!?
  2. Sooner Al
    Sooner Al Active Member
    385
    340
    Oklahoma, USA
    2016 Prius v wagon
  3. keymusic
    205
    111
    Southern California
  4. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    On the brightness adjustment, take it to the top then turn it down a notch, the auto dim feature for night time doesn't seem to work when you set the instruments to full brightness.
  5. keymusic
    205
    111
    Southern California
    I keep my brightness down a lot lower than that though. My 3rd gen Prius would auto-brighten during the day when I had my lights on no matter how low I had the cluster brightness set.
  6. keymusic
    205
    111
    Southern California
    Much to my dismay, I found out that the Two does not do this. Only the Three and above. I tested another 2017 Two and a Three at a dealer. That's really bad and also a safety issue that the instruments dim if you turn your headlights on during the day. Especially when the 3rd gen Two did do this.
    RCO likes this.
  7. 360texas
    360texas Member
    121
    35
    Fort Worth, Texas USA
    Reads like a software issue.
    RCO likes this.
  8. keymusic
    205
    111
    Southern California
    I agree. I put a call into Toyota and he said this will be followed up on. Hopefully that's true. I was very clear with them that this is a safety issue, so I assume they'll take it seriously.
    RCO likes this.
