SPECIFIC Plastic Rivets - for Side Skirt Rocker Molding Trim
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by unit333, Mar 19, 2014.
  1. unit333
    unit333 Junior Member
    77
    NYC
    Hi
    I already had a thread going for this particular damage, but after further investigation under the car i managed to take better pictures and find out exactly what i need to fix this. I need your help in identifying the black plastic rivet I need to order for this particular situation. Attached pictures has the damaged right side of the Rocker, a pic from the good left side as well as a shot of the broken plastic rivet. Any help identifying the part number or proper name would be greatly appreciated.
    Thank you
  2. unit333
    77
    NYC
    PICTURES
      File size:
      37.8 KB
      987
      File size:
      35.7 KB
      921
      File size:
      46.5 KB
      1,000
      File size:
      103.6 KB
      1,025
  3. Mike500
    Mike500 Senior Member
    2,593
    767
    I remember have lost a couple of these that wiggled out of my rocker panel covers.
    I used a couple of 7/8 inch or 22mm Heyco nylon hole plugs designed to close out open 1/2 inch nominal knock outs for electrical boxes like these on eBay.
    Most large Hardware stores will have them. I got mine at Home Depot.
    The "teeth" on these reach deeper and hold better than the originals.
    I put mine on about 6 months, ago. I just went out and checked them, and they are still in place holding tight.
  4. unit333
    77
    NYC
    Awesome, thank you!
  5. Mendel Leisk
    41,863
    This is one of the fussier plastic trim pieces. I like to figure out how to remove such items, but so far I've left that one alone. There's a crazy quantity of fragile, trouble prone fasteners. A few of those large diameter fasteners are partial broken on ours, but so far it's holding up.
    Here's the section from the Repair Manual:
    DogDaze likes this.
  6. Mike500
    2,593
    767
    2010 Toyota Prius Parts - Frank Toyota, Scion & Hyundai
    It's Item #7.
    The ones I noted are available in the drawer bins at Lowe's for $1.39 for a bag of two. They are 7/8 inch black nylon hole plugs.
    They can be ordered through Lowe's from the Grainger Catalog as Part #1ELW4 for a 25 pack, with free shipping to the Lowe's Store or to your home.
    They hold better than the OEM ones.
    DogDaze likes this.
  7. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    I have definitely developed a love/hate relationship to these plastic fasteners. Overall I'll be happier when something different comes along.
    DogDaze likes this.
  8. Mike500
    2,593
    767
    I had one pop of in the same position on each side of my 2012 "v" about 6 months, ago.
    I replaced them with the ones that I noted, 6 months, ago. They HAVE NOT come off, since.
    I'd look under your Prius"v." They may be gone, too.
    DogDaze likes this.
  9. FrankB
    FrankB Member
    117
    53
    I've had a rattle that seemed related to wind speed since I got my Prius last October that sounded like something inside either the driver's side front or rear door. After reading this thread and hearing the sound yet again this past weekend, it finally occurred to me that the sound could be coming from below the car. Sure enough, the front portion of the panel had pulled itself partially through the plug. I was able to remove the plug and reuse it for now.
    That did turn out to be the source of the sound.
    Frank
    DogDaze likes this.
  10. wbray123
    wbray123 Junior Member
    71
    Colonial Heights, VA
    I couldn't find your thread on the damage. Is it anything like mine?
    Help, Ruptured My Prius! | PriusChat
    I see a similar type fastener around the damaged parts of my piece I believe to be a rocker panel. Just wanted to see if you had the same damage and how you dealt with it. Thanks.
    DogDaze likes this.
  11. SumGai1986
    SumGai1986 New Member
    Chicago
    I know this thread was effectively closed 2 and a half years ago, but KUDOS to Mike-500 for the tip on the hole plugs. I could have spent a day chasing down the correct Toyota part number, waited a week for it to come in, and spent a LOT of money. But instead an elegant solution at the local home depot for $0.60. You sir, are brilliant!
  12. Mendel Leisk
    41,863
    Could you share a link?
    N'mind, see Mike's post.
