Is it Prudent to Neutral at 60 mph Down a Hill ?
Discussion in 'Gen 3 Prius Main Forum' started by PriusNeckBeard, Nov 8, 2016.
  1. fuzzy1
    10,409
    No more so than the even larger engine drag in the same situation on my past cars.
    Most drivers have that pattern ingrained in their intuitive driving habits, so its absence would cause other drivabilty issues and user errors.
  2. AKCoffee
    AKCoffee Junior Member
    46
    2014 Prius v wagon
    I find it difficult to software glide it with the go pedal but I've only had it for about a month. I'm driving the Civic Hybrid today...much easier to find to find the glide point with my right foot.
  3. AKCoffee
    46
    2014 Prius v wagon
    The go pedal, steering response and outward visibility are all better in the Civic.
  4. GT4Prius
    GT4Prius Active Member
    530
    412
    Cumbria, UK
    Excel
    It's not engine braking unless you're in B mode. It's v mild regen braking. See Mendel's post above.
  5. fuzzy1
    10,409
    For the regular D mode mild regen, call it 'synthetic engine braking'.
    It isn't true engine braking or drag (except when the HV battery is 'full', then it does break over to real engine drag), but it artificially creates the same effect.
