Loss of Power on Canyon Road!!!
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Vintage Pep, Nov 1, 2016.
  1. ivan pantin
    ivan pantin Junior Member
    Monterrey Mx
    No it´s not a joke.
  2. ivan pantin
    Monterrey Mx
    Update. The dealer changed the hybrid battery. The car is working normaly. Its been two weeks and everything is working normaly.
  3. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Glad it is working normally. There is a possibility the new battery actually fixed it, but it sounds more like an ECU problem. And since the HV ECU and Hybrid ECU were combined in GenIII, it is doubtful that a pack replacement replaced any ECUs...
    ivan pantin likes this.
  4. aurelio
    aurelio Member
    72
    56
    Mexico
    No lemon law down here in Mexico. There is no human way to make a car dealer to take a car back here. Once you paid, that's it, even if they haven't delivered the car yet.
    SM-T813 ?
  5. aurelio
    aurelio Member
    72
    56
    Mexico
    El consumo depende mucho del estado de la batería hibrida. ¿Qué consumo te está dando con la nueva y cuál te daba con la anterior? A mi en Tampico me está dando 5l/100 religiosamente, con arranca para continuo. Me baja hasta 4 o algo menos cuando agarro menos semáforo.
    SM-T813 ?
  6. Coast Cruiser
    Coast Cruiser Senior Member
    2,267
    2,571
    Pacific Coast Highway
    Sorry to hear that. Did they ever get the car fixed? Do they know what went wrong?
  7. ivan pantin
    Monterrey Mx
    Me esta dando 4 litros cada 100 kms. Antes con la batería que falló me estaba dando como 6 lts. Muy raro que haya fallado la batería a los 5 mil kms. Pero ya quedo. Tengo dos semanas de que lo arreglaron y todo funciona bien. Saludos.
    aurelio likes this.
  8. ivan pantin
    Monterrey Mx
    Yes they did. They changed the hybrid battery. Wasnt holding the charge. Its been two weeks and the car is working normally.
    Prodigyplace and alanclarkeau like this.
  9. Coast Cruiser
    2,267
    2,571
    Thanks. Hard to believe the hybrid battery went bad on a brand new 2016 Prius.
    Prodigyplace and ivan pantin like this.
  10. aurelio
    aurelio Member
    72
    56
    Mexico
    Consumption was a 50% higher with the bad one, like previous generations. Good information to diagnose failures.
    SM-T813 ?
  11. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    How did I miss this thread?
    Well too late to this party..BUT...
    At this point in my life...I blame everything negative on "Rats".
    Even bad haircuts.
    RCO likes this.
  12. ivan pantin
    Monterrey Mx
    Update. Two months ago the dealer changed the hybrid battery. Last night again no power the battery indicator was at two lines. Engine trying to charge the batteries for 15 minutes and the bars stayed at two lines. Today the is working normally.
  13. ivan pantin
    Monterrey Mx
    Any ideas what could it be? Taking the car to the dealer again for the fourth time.
  14. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    No codes? Check Engine Light (CEL)?
  15. Mendel Leisk
    41,824
    I vote lemon. Toyota needs to step up?
  16. ivan pantin
    Monterrey Mx
  17. fotomoto
    5,639
    3,815
    So. Texas
    My guess: inverter or inverter software.
  18. bisco
    52,286
    sounds like the gen 4 might be toyota's most plagued vehicle to date. i really thought they would put more effort into this one.(n)
    Coast Cruiser, RCO and ivan pantin like this.
  19. ETC(SS)
    7,312
  20. Mendel Leisk
    41,824
    I would still explore that avenue, regardless. No manufacturer wants bad publicity.
