CTEK MXS 5.0 vs NOCO GENIUS 3500
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by MeGuinness, Dec 3, 2016.
  1. MeGuinness
    MeGuinness Member
    217
    78
    UK
    Any suggestions on which of the two to charge the Prius agm battery?
    Anyone with experience on both chargers? Thanx
  2. Mendel Leisk
    42,168
    The CTEK MXS 5.0 seems roughly akin to my (North American) Multi US 4.3, albeit with 5.0 amps vs 4.3. I see there's also MXS 3.8 on the GB site, another worth considering. The latter is (like the name) rated 3.8 amps.
    I've got a feeling either the 3.8 or 5.0 would be fine, but for the record, Owner's Manual says 4.2 amp max (North American version, page 439).
    I have both the (North American) Multi US 3300 and 4.3. I now use the 4.3, figuring it's a bit faster, though I don't really see any difference in practice. The 3300 (akin to GB MSX 3.8 in style/functions) I find simpler/easier to use. It's cheaper, likely just as good.
    Sorry, no clue about the other brand.
  3. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    I have a Genius 3500 and I used it to charge up my new replacement Canadian Tire battery (probably Exide AGM) before installation. Seems to work fine. I use a "Battery Tender" on Pearl S in winter when she is hibernating. It's on there now in fact. The Genius is on the workbench for mucking about with batteries. I've used it on the FJ Cruiser once, for "test purposes". ;)
  4. MeGuinness
    MeGuinness Member
    217
    78
    UK
    I decided to get the ctek because of the desulfating feature,will let u know how it goes
  5. MeGuinness
    MeGuinness Member
    217
    78
    UK
    Update ,
    I keept the battery under charge in recon mode ....... Fitted the battery back and this is the reading I get with everything off ,and I mean nothing is on ,the reading from the obd works without switching anything.
    Same value from self diagnostic display...
    With multimeter at the battery post I get 12v.
    What do u think guys?
  6. Mendel Leisk
    42,168
    You say with multimeter you get 12 volt? Like 12.0?
    Especially with freshly charged battery, with surface charge, not good. Should be close to 13 volt.
    An ex battery? (Monty Python Pet Shop sketch)
    Direct connection of something like Solar BA5 at the posts would resolve the questions.
  7. MeGuinness
    MeGuinness Member
    217
    78
    UK
    Yes the solar BA5 cost only £185
    Sorry my mistake ..Is about£50
    #7 MeGuinness, Dec 29, 2016
  8. Mendel Leisk
    42,168
    Yeah mine was around $70 Canadian dollars? Any competent battery retailer should have a pro version of the same, and would likely be willing to do a gratis check.
    What's the history of your battery again? If I recall correctly it's not that old?
    If it's in fact got at-rest voltage around 12.0 volt, might be time to wash your hands of it, start again. If a battery sits for protracted time at low voltage it's hard to recover bring it back.
  9. MeGuinness
    MeGuinness Member
    217
    78
    UK
    The battery is the original one ,7 years old next week 190k on the clock
    Raytheeagle likes this.
  10. MeGuinness
    MeGuinness Member
    217
    78
    UK
    I decided to get a new battery,due to the car milage the Toyota recommended battery will outlast the life of the car so I'm getting a cheap Varta B33 Blue Dynamic for £45 ,that should do for what is left of the life of the Prius ....about untill January 2018
