who has most miles of 2016 Prius?
Discussion in 'Gen 4 Prius Main Forum' started by GaryD1, Dec 7, 2016.
  1. GaryD1
    GaryD1 Active Member
    302
    138
    Seagrove, NC
    I got 8,400 miles since September
    RCO likes this.
  2. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Will this be your regular mileage, or just a one-off?
  3. IAPrius
    IAPrius Active Member
    120
    140
    West Des Moines, IA
    I have hit 9,950 since August 1.
    GaryD1 likes this.
  4. GaryD1
    302
    138
    Seagrove, NC
    Hey GaryD1, you mean: who has most mile on their 2016 Prius, yes that is right, oh ok!
  5. Frankemtp
    Frankemtp Junior Member
    Chicago, IL
    Four Touring
    GaryD1 likes this.
  6. ATHiker
    ATHiker Senior Member
    644
    560
    Massachusetts
    Four Touring
    31,500 +/-
    goldfinger and wjtracy like this.
  7. GaryD1
    302
    138
    Seagrove, NC
    U had any problems so far, none here. I'm debating buying another one the last of 2017, am interested in how durable the new Prius is going to be.
  8. ATHiker
    644
    560
    Massachusetts
    Four Touring
    Not really, but it is still very new.
    The only things less than perfect:
    1. Front cone (only) has a lot of small paint chips from rocks.
    2. The black 17" wheels get dinged up a bit from careless use of a socket wrench when rotated
    3. My right front radio speaker buzzes -- but only intermittently on AM talk radio-- odd, right?
    4. I had 2 multiple rebooting events on my radio -- months apart
    5. Parking sensor recall and brake recall
    I am still debating on whether or not to take the car in to have the radio looked at while I am still under warantee. Tires are doing well -- 8mm at 30k if I recall.
    GaryD1 and RCO like this.
  9. soldierguy
    soldierguy Active Member
    108
    245
    Maryland
    34,500 since May 1st, or just a hair under 5000 miles per month...my commute is why I got the Prius. 225-230 miles per day, round trip.
    The only things that have gone wrong (if you can call it that) is:
    - I'm getting a little rattle that sounds like an exhaust heat shield when the engine is at very low RPM.
    - I get a minor squeak (increases/decreases with road speed) that I notice only around parking lots when the steering wheel is turned just a little to the left.
    At my last service in November, the service writer said they should be able to take care of the parking brake recall at the service I'm going in for this morning. If not, no big deal...I'll be back there in January for the 40K service. And hopefully they'll be able to address the rattle and squeak today as well...we shall see.
    RCO likes this.
  10. MagyarPrius
    MagyarPrius Member
    33
    28
    Lakeland, FL
    2019 Prius
    I've got around 9400 on my 2016, but had the dealer replace the streaking wiper-blades. I have had the air-bag recall and the parking brake cable recall taken care of. This occurred last Friday in Venice, Florida. Other than that, no issues at all.
  11. ETP
    2,802
    1,170
    Auburdale FL
    9500 on one of my touring's.
  12. ETP
    2,802
    1,170
    Auburdale FL
    I am thinking of moving to Lakeland any spots to avoid?
    looking at Tuscany Woods.
  13. RyanM
    RyanM Member
    68
    40
    Wisconsin
    I see on Fuelly you have 40k miles logged now, congrats! You are most likely one of the highest out there unless there are professional drivers using the 4th gen already (taxi, courier, etc)
    Your 230 mile commute is just to get TO work, not actual work. Does your work compensate for drive time/ mileage? Or do you still put in your full day of work be it 8, 9, or 10 hours, then commute back home (~115 miles?)?
  14. soldierguy
    108
    245
    Maryland
    8-9 hour days at work, plus the 2-2.5 hours commute each way (4-4.5 hours total time in the car on a typical day). It's long days, but a great job. It's a situation where there is really not much that is closer to where I work that's also a good place to live, so I commute. Also, because my husband is a student very close to home, one or both of us is going to have a big commute, and his schedule tends to be a little more unpredictable than mine, in terms of demands on time. No mileage or time compensation, but the people I work with are very flexible...if I need to now and then, I can do some stuff from home, so if for example the weather makes it unsafe for me to come in, I can stay at home and do at least some stuff from there.
    The commute is obviously not ideal, but it's truly a fantastic job, and it all works.
    Prodigyplace and RCO like this.
  15. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Congratulations. I admire your spirit and tenacity. You and hubby deserve to succeed.
  16. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Not me, 2595 miles in 10 months. :rolleyes:
    soldierguy and RCO like this.
  17. William Redoubt
    William Redoubt Senior Member
    1,226
    1,171
    Coronado Island, California
    27,500 and counting ... Virtually no issues. Change oil every 5,000 with Mobil 1 0W20.
    RCO likes this.
  18. William Redoubt
    1,226
    1,171
    That radio issue sounds like a speaker going bad to me. Is that the speaker in the dash, or the door?
    RCO likes this.
  19. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    ... Nor me, but I have managed 3,050 in two months! I've just completed an ipsos.de survey on my Prius for Toyota. Don't suppose they'll change anything even if they do read all about it.:cautious:
    kithmo likes this.
  20. RyanM
    RyanM Member
    68
    40
    Wisconsin
    I had a friend in TX where him and his wife were both driving almost 3 hours in the opposite direction to work every day. I believe his commute was close to 200 one way, at 70-80mph. This was in 2008-2010. Since then, they have relocated.
    I am very curious what it is you do for work. I need to find a fantastic job for myself!
