Charge mode
Discussion in 'Prime Main Forum (2017-2022)' started by park187, Dec 22, 2016.
  1. Mister MMT
    Mister MMT Active Member
    285
    142
    Germany
    It is a shame Toyota does not offer it yet, then!
    Jan
  2. Tideland Prius
    16,609
    A 4th point and possibly only relatable to European owners, the CHG mode ensures that there's enough battery charge to travel within city limits or districts where the car must be in EV mode.
    A side benefit for CHG mode is if you arrive at a destination without charging but wish to use the battery for pre-heat or pre-cool. This one is not about efficiency but it's more for comfort/convenience.
  3. civicdriver06
    civicdriver06 Active Member
    797
    324
    Germany
    Even if Charge-Mode seems slightly inefficient,I can't praise Toyota enough for implementing it !
    I will definitely make use of it !
    Andyprius1 and priuscatprimeguy like this.
  4. bisco
    52,349
    i kinda surprised carb allows it. maybe they're not hip to the issue.
  5. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    What I mean is this.
    Take a look at this graphic from this Toyota video.
    If driving puts you in the lower-left corner because torque is really low, as it would be at low speed or on a gradual downhill stretch, charge mode could put you up closer to the red area. When I tried charge mode on a Prime, rpm noticeably increased, indicating to me that it tried to follow that blue curve up and to the right. If that thermal efficiency increase is sufficient to overcome the losses from generation and battery in-out losses, there could be an overall advantage. Of course, we'd need numbers of the above charts, and knowledge of the system losses to make that determination, and we have neither of those so this is just a possibility without testing.
  6. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    Thanks, that's good to know.
  7. Andyprius1
    2,327
    859
    Cool CA
    Model I have is the Prime Plus, the basic model. Bisco
    Do you expect Toyota to answer this ? The answer may be profuse in the math of ME and graphs and cicumstantial variations. Just be happy, ITS CHARGING.
  8. Andyprius1
    2,327
    859
    Cool CA
    Is that from your other non-hybrid?
  9. Andyprius1
    2,327
    859
    Cool CA
    HEAR HEAR.
  10. Tideland Prius
    16,609
    @Andyprius1 please use the multi-quote function. It's much easier to read and saves space. Thank you.
  11. Lee Jay
    5,850
    4,036
    I find it much harder to read.
  12. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    The yellow area inside the red one indicates the new +40% thermal efficiency (the "raise" part of the statement).
    This indicates to me that even if you are inside the red area but to the left to the yellow - charge mode will increase thermal efficiency, this may expand to 'moderate speeds flat ground'.
    I suspect that in charge mode the charge rate is constant (irrelevant of speed), so a simple test when the car is stationary may reveal this rate and the time required to charge from 'empty' to '80% full'.
  13. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    Well, I am with Mister MMT here, would like to know! If it is speed related, then at several constant speeds.
    #73 giora, Jan 7, 2017
  14. JamesBurke
    JamesBurke Senior Member
    1,222
    493
    27
    Morgantown, WV
  15. bisco
    52,349
    the testing would have to be repeatable over the same course and weather conditions.
  16. bhtooefr
    bhtooefr Senior Member
    1,396
    1,489
    Newark, OH, USA
    And, also, even the Liftback is capable of bringing engine demand high enough to get more efficient, and then cycle the ICE and run on battery for a while. It's far less likely to do that when cruise control is enabled, but I've seen it kill the ICE as high as 73 MPH.
