2007 Prius stop...want go in reverse or drive
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Alex2604, Dec 30, 2016.
  1. Alex2604
    Alex2604 New Member
    Montgomery
    My 2007 Prius stopped running about a month ago. My son left the house and went maybe half mile and it started to run very slow. Eventually it stopped and wouldn't go in reverse or drive only neutral. It was towed back to our house. Soon after the battery in the trunk (which was new) died. Well I had the battery charged yesterday and the dash lights came on but it still want start. I've been reading since yesterday that it could be out of gas. The fuel light is blinking. About a week before the car stopped running I had a problem pumping as at the gas station. The pump kept stopping. I had the gas attendant check the pump and it worked fine. He said it had to be a problem with my gas tank. So I moved to another pump and was able to put a little gas in it but it said it was full but it shouldn't have been. Which leads me to think it could be out gas.
  2. Alex2604
    Alex2604 New Member
    Montgomery
    Before it stopped all the dashboard lights came on including the red triangle.
  3. bisco
    49,693
    could be a lot of things. you need to test the 12v, have the codes read, make sure there is at least 3 gallons of gas, check inverter pump fluid movement, oil level and so on.
    how many miles on her?
  4. JC91006
    JC91006 Senior Member
    16,493
    8,403
    After charging the battery, disconnect the negative terminal for few seconds, reconnect then restart.
    It should start. Shut down and try to start again. If it starts a second time, then it's not as serious. If it doesn't start a 2nd time, then you have a bigger problem
  5. Alex2604
    Alex2604 New Member
    Montgomery
    It's has a little over 150,000 miles.. maybe 150,300
  6. Alex2604
    Alex2604 New Member
    Montgomery
  7. Alex2604
    Alex2604 New Member
    Montgomery
    Also I took the battery back to the Toyota dealer and it tested fine. I'll put the gas in it and see what happens.
  8. bisco
    49,693
    when you have trouble getting gas in, try a different pump, or open the cap and let it breathe for a minute. you can also try pumping as slowly as possible, and also holding the handle at 45 and 90 degrees. all the best. (y)
  9. Alex2604
    Alex2604 New Member
    Montgomery
    Ok. Thanks for your help.
  10. Alex2604
    Alex2604 New Member
    Montgomery
    So we added a little over 3 gallons of gas and the car didn't register it or start. Added another 2 gallons and disconnected the neutral terminal and it still didn't start. The car never registered the gas. Light still blinking. Any more suggestions?
  11. JC91006
    16,493
    8,403
    Have you messed with the orange plug on the hybrid battery?
  12. Alex2604
    Alex2604 New Member
    Montgomery
    No we have not.
  13. JC91006
    16,493
    8,403
    Then just let the car stay on for a few minutes until the blinking fuel registers. Your car should start
  14. dolj
    dolj Senior Member
    7,741
    3,919
    Wellington, New Zealand
    Don't forget to press the Power button twice.
  15. Alex2604
    Alex2604 New Member
    Montgomery
    Ok. I'll try it again tomorrow. Thank you both.
  16. JC91006
    16,493
    8,403
    If it doesn't start tomorrow, you'll need a pro to sort this out. Could be a fuel pump issue
  17. Alex2604
    Alex2604 New Member
    Montgomery
    Ok. Thanks.
  18. bisco
    49,693
    you'll have to go to the dealer and have the trouble codes read, unless you're capable of diy. you can try an auto parts store, but their readers aren't always specific enough.
    trying to understand what killed your new 12v battery, that's unusual.
