2017 prime premium, CEL after first day?
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by omarsayeed, Jan 3, 2017.
  1. omarsayeed
    omarsayeed Junior Member
    Alexandria, VA
    Anyone know how to turn off the check engine light without unplugging terminals?
    iPhone ?
    52,278
    welcome!
    first you need to find the culprit. is the gas cap tight? if you fix the cause, it goes away on its own after a few drives.
    Trollbait likes this.
  3. huskers
    huskers Senior Member
    2,544
    2,487
    Nebraska
    Penny's car has had that problem for years. Drives Sheldon batty.
  4. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    If the problem is minor and it "repairs" itself or the fix is found, it will cancel itself out after a few power cycles. If not, the easiest way is to get an OBD device or some auto parts stores will do it for you for free.
    But the question still remains, Why is it on?
    Trollbait and priuscatprimeguy like this.
  5. omarsayeed
    Alexandria, VA
    ...and it went away on its own after a few hours
    iPhone ?
  6. bisco
    52,278
    probably a brainfart.
