How do you use your headlights?
Discussion in 'Gen 4 Prius Main Forum' started by gvp1995, Aug 23, 2016.
  1. Coast Cruiser
    Coast Cruiser Senior Member
    2,267
    2,571
    Pacific Coast Highway
    .....and they stay nice and cool because water collects in there. :eek: I have Goldfish in mine. A mini aquarium.
  2. MichelleStone
    MichelleStone Senior Member
    549
    818
    Mariposa, CA
    I have red and blue betas in mine. One for each headlight.
    RCO and Coast Cruiser like this.
  3. MagyarPrius
    MagyarPrius Member
    33
    28
    Lakeland, FL
    2019 Prius
    I keep mine on DRL, and then when it's "dark-time", I turn them on completely. I believe in making one's self as visible as possible during the day, unless I'm robbing banks. When robbing banks, I use the "cloak" setting.
  4. William Redoubt
    William Redoubt Senior Member
    1,228
    1,173
    Coronado Island, California
    LOL. It rains three times a year in SoCal, although I remember two years ago there was snow on the I-15 in Lake Elsinore just north of San Diego. In the past week we have had 4 years' worth of rain.
    MichelleStone likes this.
  5. Coast Cruiser
    2,267
    2,571
    Headlights
    • It is the law in California to have headlights on when it’s raining, foggy, snowing or even cloudy. If you must use your windshield wipers, you are required to have your headlights on.
    • You must have your headlights on if you cannot see at least 1,000 feet in front of you.
    • You must turn on your headlights at least 30 minutes after sunset and not turn them off until 30 minutes before sunrise.
    • The California driver’s handbook also recommends using headlights on country roads or up in the mountains even on sunny days to make it easy for other drivers to see you.
    I think Prius drivers are some of the worst offenders. Very rarely (never!) do I ever see a Gen2 or Gen3 with their DRL's on. (The Prius is a pretty small car, I like to do everything I can to stay visible). I don't care what arguments they throw up, having the lights on doesn't hurt the gas mileage at all.
    Overall, in general, I think only about 40% of all drivers in So Cal use daytime running lights. And about the same amount when it's gloomy rainy and stormy. Makes no sense to me.
  6. Prodigyplace
    12,643
    11,818
    Central Virginia
    Perhaps drivers there are fed up with those who use headlights that are aimed too high. Since you are being flashed do the other drivers a favor and get them aimed
    I am sure that California law addresses headlight aiming too.
    EDIT In another thread you clarified that you are not flashed regularly The impression was given that you were flashed and did not care. I also apologized in the other thread too.
    Those complaining about being regularly flashed need to take the issue seriously though.
    #66 Prodigyplace, Jan 4, 2017
  7. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Do you think the climate there may be changing or something? Disney's duck might disagree!
  8. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    It's a strange thing CC. If you give someone a 2-way radio they will feel compelled to use it, even if there's nothing needs to be said. On the other hand, you can give some folks headlamps and DRLs to help see and be seen and for some reason they will simply turn them off. It's like they can't afford the resultant electricity bill!!! (n)(n)(n)
  9. Prodigyplace
    12,643
    11,818
    Central Virginia
    This is the first car I have owned where you can disable DRLs. They are always on for my 2000 Tundra (part of an option with ABS) and my 2008 Corolla.
    I do not see the purpose of the Off setting for DRLs.
  10. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    This is my first car with them - since my 1980 VOLVO 244. Between 1980 and 2016, I've had 11 cars, all without DRLs.
  11. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    It's only USA that has the off facility!
    #71 RCO, Jan 4, 2017
    alanclarkeau likes this.
  12. Prodigyplace
    12,643
    11,818
    Central Virginia
    If that is the case perhaps @Prius Team can enlighten us to the logic in play here.
    They are Toyota US Prius marketing team.
  13. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    We can't turn the lights off here in the UK, unless the car is powered off. The DRLs come on when you power up and go off when the headlights come on or when you switch to sidelights (parking lights). This means the only way we can go incognito is if we power off the car, no good for a getaway. :whistle:
    alanclarkeau and RCO like this.
  14. Prodigyplace
    12,643
    11,818
    Central Virginia
    Ours usually turn on when you put the vehicle in gear (Drive or Reverse) and then turn off when you power off or, sometimes, when you turn on other lights.
    Still no good for a getaway, except in a Prius. Remember last year's Prius Super Bowl commercials? :LOL:
    Not everyone is laughing at this Prius Super Bowl commercial - The Washington Post
    And the followup:
    #74 Prodigyplace, Jan 4, 2017
    kithmo likes this.
  15. Tideland Prius
    16,607
    I assume your DRLs are the 3 vertical LEDs. They're much less conspicuous. Ours are the low beams at a slightly reduced output. So this will test the reliability of the Prius' LED headlight system since they'll be on much more often than any other Prius in the world.
    alanclarkeau and Prodigyplace like this.
  16. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    While it's true our DRLs are smaller, the light intensity is brighter than the larger but dimmed heads and quite conspicuous. I have noticed the reflection back from the vehicle on front of me when stopped at a junction, etc.
  17. Prodigyplace
    12,643
    11,818
    Central Virginia
    I do not like it because I am used to turning the stalk all the way to turn off the Headlights. Now I need to check that I leave the DRLs on.
    I probably drove my first couple of days with DRLs off until I realized that the DRLs were off.
  18. Prodigyplace
    12,643
    11,818
    Central Virginia
    I have DRLs on 2 other Toyota's but they do not have this (choose: bug or feature?). On the other vehicles, DRLs turn on when the vehicle is put in gear and turn off when the vehicle is turned off.
  19. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    As far as I was aware, that's exactly how DRLs worked, at least on European models.
  20. Prodigyplace
    12,643
    11,818
    Central Virginia
    I saw another UK comment that said their DRLs turned on when they turned the vehicle on, not when it was placed in gear.
