Gen2 to Gen4 hv upgrade
Discussion in 'Gen 2 Prius Technical Discussion' started by JCM808, Feb 3, 2017.
  1. JCM808
    JCM808 New Member
    US
    Looking to buy one of 2 used Prius' I found where I live in Maui. The problem with them both is the HV batteries won hold a charge. I am going to buy one of them and replace the hv battery ether with replacement gen2 mods or if it is possible upgrade them to the new gen4 packs. Any thoughts on this adventure?
  2. Prodigyplace
    Prodigyplace Senior Member
    11,696
    11,318
    Central Virginia
    One of the hybrid experts here said the Gen 4 modules can be used in the Gen 3 pack. They may also work in the Gen 2 pack. I assume the Gen 4 pack would not work as a unit.
    You would need to find a Gen 4 NiMH pack from a US Trim Two, though. The Lithium Ion ones from the other US trims would not work.
  3. bisco
    49,434
  4. Prodigyplace
    11,696
    11,318
    Central Virginia
  5. JCM808
    JCM808 New Member
    US
    Thank you both I will be looking to that post and seeing what I can come up with for a car now. :)
  6. bisco
    49,434
    the title is 'Gen 4 cells in a Gen 2'
