Fan noise much too loud
Discussion in 'Prime Main Forum (2017-2022)' started by Dhuntj, Feb 5, 2017.
  1. Dhuntj
    Dhuntj New Member
    washington
    Noise is coming form the front of the engine compartment
  2. Dhuntj
    Dhuntj New Member
    washington
    It's the fan in the front of the engine compartment.
  3. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    are you plugged in?
  4. Dhuntj
    Dhuntj New Member
    washington
    The problem noise is intermittent but it typically occurs when I drive relatively hard in EV. I took it to the dealer and, of course, they couldn't reproduce the problem but had a good suggestion - video tape it when it occurs. So, when I arrive home earlier this week it was really howling with no ICE running. I was able to video it and plan to get it to the dealer on Friday or Sat. It doesn't appear to be the main fan. I'll check back when I find out more.
  5. VTBIGDOG
    VTBIGDOG Active Member
    211
    146
    And the dealer said......?
    priuscatprimeguy likes this.
  6. priuscatprimeguy
    2,730
    2,640
    inquiring minds want to know:cool:
  7. bisco
    52,093
    tomorrow is our one month anniversary!;)
  8. priuscatprimeguy
    2,730
    2,640
    should we bring a gift?:rolleyes:
  9. bisco
    52,093
    new fan?
  10. priuscatprimeguy
    2,730
    2,640
    nah, earplugs:D
  11. bisco
    52,093
    see, that's the good thing about going deaf.
  12. priuscatprimeguy
    2,730
    2,640
    WHAT?:confused:
    Prodigyplace likes this.
  13. Since2002
    Since2002 Senior Lurker
    936
    1,098
    Duluth, GA
    Maybe he got sidetracked trying to figure out how to turn off the pedestrian noise maker and the reverse beeping.
  14. hatcher8
    hatcher8 Junior Member
    32
    Lincoln Ne
    I have fan noise coming from the engine compartment near the front left quadrant of the engine compartment. I have noticed it twice now and both times it occurred when I had the heater set to warm up the interior of the vehicle
    One time it was plugged in and the second time it was running on its own and I can't remember what mode it was in if it was in EV or HV.
    One of the salesman once told me that these Prius Prime's have actual heat pumps in them instead of just air conditioners
    I'm not sure if that's true or not but I do know that heat pumps for residential homes can make horrendous noises when the pumps are running. I have an appointment at the dealer to look. I think on the 16th of March so I'll try to report back
    Pearl Prime
  15. bisco
    52,093
    yes, it is true. there's a residential heat pump near us, sounds like the loudest buzzer i've ever heard.
  16. hatcher8
    32
    Lincoln Ne
  17. mdhare
    mdhare Member
    59
    33
    Madison, WI
    Our premium does this when preheating as well, nice and loud in the garage. I just assume it is normal behavior from the heat pump. Look forward to your dealer confirmation.
    hatcher8 likes this.
  18. mr88cet
    mr88cet Senior Member
    2,313
    1,335
    Austin, TX
    Hmmm... I don't have much real-world experience with heat pumps (Austin heating needs are pretty light). Conceptually speaking though, a heat pump is an air conditioner that cools the outdoors, so right off the top of my head, I can immediately think why it would be much louder than an air conditioner...
    Lee Jay likes this.
  19. bisco
    52,093
    thinking about how a heat pump works is like thinking about hsd. i need graphics.
  20. I'mJp
    I'mJp Senior Member
    628
    552
    Ma, USA
    Two heat exchangers seperated by a compressor and a expansion valve. try wiki
